Dyna cam replacement?
Old Sep 9, 2013 | 08:23 PM
deuce_streetbob's Avatar
deuce_streetbob
We should start a cam tool borrow program where whoever needs it pays for the shipping, then sends it back after using. I hate buying a single use tool, especially when it's over $100. Lol.
Side note, anyone know of a basic gasket/o-ring kit that gives u what u need if cutting the pushrods out? Seems most kits give u way more assuming u will pull the heads. So, basic gaskets and bearings.
Old Sep 12, 2013 | 08:52 AM
Jake8092's Avatar
Jake8092
Stage IV
I hear ya on the cam bearing tool...
Fuel moto sells a basic kit for about 150 bucks
Old Sep 12, 2013 | 09:49 AM
Inspector 12's Avatar
Inspector 12
Originally Posted by Hogpro
The 255 peters out at 4000 rpm's. Depends on your riding style.
Your statement is only half true. Yes torque does start to drop around 4500 but horsepower is rising and meets torque at this point. Net effect is the bike pulls hard to 5500 which is as hard as I twist the engine with SE 255's in it anyway. Torque gets you off the starting line, horsepower carries you to the finish line.
Old Sep 12, 2013 | 09:55 AM
Hogpro's Avatar
Hogpro
Former Sponsor
All I am saying is that there are better options out there. Far better.
Old Sep 12, 2013 | 03:16 PM
Inspector 12
I understand you were stating an opinion, you also in your original comment stated a lot of it would depend on the OP's riding style.
I was merely stating my experience that SE 255 cams are not nearly as bad as some would propose. After four seasons of running them, I can't think of a reason to swap them out other than if they were to get damaged.
The OP as he indicated he was interested in the SE 255's based on price and a conservative two up riding style. Other cams may work better related to timing of the torque and horsepower curves but at increased cost. The SE 255's generally bolt in without too many changes.
Old Sep 13, 2013 | 08:31 AM
spdrcrjl's Avatar
spdrcrjl
"The SE 255's generally bolt in without too many changes." That's another factor.
HD_Matt
Aug 11, 2016 03:32 PM
dzzbob
Oct 25, 2015 09:34 AM
InthewindMN
Apr 15, 2015 02:47 PM
Firechaser1141
Oct 23, 2013 07:08 PM
a34655
May 16, 2010 08:44 AM
