So I took out one spring and spacer and according to progressive website I do have the right spring and spacer. It seams like everything is a cluster f^$#@K lately as far as getting the right parts for this bike
Before I started it took some measurements to make sure that these springs did not lower the front end.I put it all back together took the measurements again and nothing changed.
I put amsoil 10wt shock therapy in with the new springs.Just pushing the bike forward and pulling the front brake there is a big difference in how the front dives now compared to before the new springs.Tomorrow Ill see how it rides
Just ride it first before making any changes.
I had a similar experience on my 2004 Lowrider, it was easy to re install the fork cap after the Progressive springs were in.
I've used progressive springs before and even though I thought the front end felt more stable, I didn't think the ride was better. The best improvement I've found are the ricor intimidators with the amzoil shock therapy. One better would be the intimidators with a "single rate" spring made for your weight.
Even with these uprades, you have to make sure you dial in your front in with the proper sag for your weight. (adjusted by cutting or lengthening the spacer) This usually means you have to take measurements with just the bike, the bike with your weight, and the measurements of your forks fully extended. (on a lift) To get it really dialed in you will be taking it apart more then once but once it's set up properly, it will be set for life and you will see a huge difference.
I have done the intimidators with the 10w amzoil therapy fork oil (eventually changing to 5w) The intimidators adjust to whatever your traveling over from railroad tracks to scraped roads, tar snakes....I never stress over the front end anymore and have no jarring no matter what I ride over.
You do realize the HD springs are a progressive type? Take a look at them
I already told you that. You have to go by HD fork oil settings. It's a HD bike not a progressive bike. You are not changing the volume of the fork tubes.
Obviously their directions cover more then just your year and model otherise you would have the right spacer bar. If it was me I would just return it...but it's your bike
How did you drain the fork oil, did you pull the forks off the bike ?
