2012 FXDC - Forward Control Install
Old Sep 24, 2013 | 03:59 PM
HectorBuddy's Avatar
HectorBuddy
6th Gear
Default 2012 FXDC - Forward Control Install
I recently ordered and installed Kuryakyn 9064 Extended Forward Control set.
The instructions were worst I have seen to date for anything that needs to be assembled and installed. My stock pegs would not fit the brackets and I'm thankful that I already had the Triple Traps to use.
What should have only taken about an hour and a half to install and test took about 4 hours with a trip to the hardware store for an extra wrench (1/4 inch hex). I can confidently say that if I need to do this install again on a friends bike it will be so much faster.
Attached Thumbnails 2012 FXDC - Forward Control Install-imag0035-2-.jpg   2012 FXDC - Forward Control Install-imag0037.jpg   2012 FXDC - Forward Control Install-imag0036-2-.jpg
Old Sep 24, 2013 | 04:31 PM
128auto's Avatar
128auto
I have the same one except extender. Yes instruction is horrible, you figure it out lol.
How come the shifter linkage isn't straight? New design?
You should cut the stock shifter rod, take it right out, look way better.
Old Sep 25, 2013 | 09:30 AM
HectorBuddy
6th Gear
I think my shifter linkage has the bend in it because it's the extended version. Using a straight one would hit the case.
Biggzie
Oct 4, 2017 07:52 PM
mcwarren
Jan 14, 2015 07:11 PM
128auto
Mar 7, 2013 07:12 PM
128auto
Jun 9, 2011 11:33 AM
pdiddles
May 1, 2007 11:06 PM
