Leave it in or pull it out?
Old Oct 8, 2013 | 11:08 AM
  #31
Sharkman73's Avatar
Sharkman73
Originally Posted by Bear_Bob
It really depends....if there is no chance of repercussions, I usually leave it in...it rides better; but you have to be sure. Any chance of long-lasting side effects--you have to pull it out!
Good advise to live by here!
On a serious note, it looks like you could be ok to ride it as is possibly. Not sure if they make some kind of filler specifically for this situation or not, but I would look into it. It would make me nervous though & I would consider a new tire.
I got a nail in a tire one time. Ironically, I was on my way to get new tires installed. I noticed the rear was acting squirrely, so I stopped to investigate. It was a large nail in the rear tire & it was leaking pretty bad. I stopped frequently to check pressure & had to air it up once or twice during the trip. Had it been on the front, I would have called for a haul, but since it was the rear I just rode it out slowly & made it.
Old Oct 8, 2013 | 01:55 PM
  #32
Red Dragons's Avatar
Red Dragons
Thanks for all the input guys. I feel like it's safe after looking it over. The screw was only 1/4 long and luckily went in at the highest point of the tread. I am going to look into some sort of filler, although just some good ole black RTV might be the best thing there is, though I doubt it really matters. Luckily the FB front is quite meaty.
Old Oct 8, 2013 | 07:13 PM
  #33
Junkster's Avatar
Junkster
Get some of that windshield sealant. Goopy as hell but cures out pretty tough.
Old Oct 8, 2013 | 08:35 PM
  #34
shadowbob's Avatar
shadowbob
The patch on the inside was assuming it penetrated all the way through
Old Oct 9, 2013 | 10:00 PM
  #35
davidearlcox's Avatar
davidearlcox
I really don't see any advantage to trying to fill the hole, as small as it would have to be. I'm thinking it might be about as worthwhile as trying to fill the tread grooves themselves.
The bottom line is if there is no leak and the cord is undamaged, I can't see any reason it shouldn't be good to go as is.
thunderstorm
Sep 11, 2016 03:53 PM
Jim Kraft
Sep 3, 2012 03:16 PM
2004Sierra
May 27, 2011 08:16 PM
oilhog
Jun 30, 2007 11:52 AM
harleyboy63401
May 26, 2005 09:48 AM
