Switching bars
Old Oct 11, 2013 | 11:17 AM
JonnyLew's Avatar
JonnyLew
hmm..options..do you know which dyna models have the same fork width as the street bob? i know i ran into this problem with my zx9r interchangability..
Old Oct 11, 2013 | 11:27 AM
JonnyLew's Avatar
JonnyLew
west coast t-bars has bars for the street bob with bracket welded right to the bottom thats the route il be going
Old Oct 11, 2013 | 11:28 AM
glideridemike's Avatar
glideridemike
If you have a decent dealership nearby you should be able to call the Parts Dept for pertinent info about the bars and possible replacement info.
Old Oct 11, 2013 | 01:45 PM
JAFlanders's Avatar
JAFlanders
Default New cables and brake lines
When buying new bars, a rough formula to follow is to measure the increased heigth + 1/2 the increased pullback that the new bars will give you. This amount will be very close to how much additional cable and brake line that you may need. However, the best method is to fit the new bars to the motorcycle and then make the increased length determinations, if needed at all.
http://www.sideroadcycles.com/Americ...andlebars.html
Old May 28, 2014 | 07:04 PM
rmiller666's Avatar
rmiller666
2nd Gear
Default Your bars
Originally Posted by chris h.
Road 6 Holy Rollers
I'm curious which bars you have, the wide (11.5") or the narrow (9.75")? And the rise? Also of you have any more pictures I'd love to see them, trying to make the choice for my own bars. Thanks.
Old May 28, 2014 | 07:14 PM
mikeg212001's Avatar
mikeg212001
Originally Posted by JonnyLew
sorry to jump the thread but what about t-bars ? do you just remove the riser and bolt to top tripple tree ?
you have a new street bob, dont you? If so, your options for bars are almost limitless. Harley got rid of the integrated risers for the '13 and newer sb. Its the '12 and older bobs that are limited on options.
Old May 28, 2014 | 08:38 PM
AussieTX's Avatar
AussieTX
Originally Posted by Guitarman_sg
The only way to put T-Bars on a Street Bob is to change the trees. Probably be better off to get the riser extensions and go with a broom handle bar with some pullback?
West coast t bars make a set designed for the street bob with the integrated risers.
Old May 29, 2014 | 12:52 AM
Ohello232's Avatar
Ohello232
6th Gear
Wut kinda of license plate holder is that and where did you find it?
SavageChopper
Milwaukee Eight (M8)
Sep 13, 2017 05:25 PM
kreeess
Feb 15, 2016 09:55 AM
galaxyfe
May 16, 2015 07:25 PM
mgmmgm
Oct 28, 2012 06:55 PM
HDF Tech
Sep 9, 2005 02:56 PM
