Thanks for the pic i really appriciate it Did you guys remove the whole box that has all the electrical stuff in it what that cover covers? I removed the 2 torx screws at the top and the thing still wont budge.
There are 3allen screws holding it on ( my 06 WG there is anyway), you most likely are missing one that is in the middle of it all. Then the only thing holding it in is the wiring. It may help getting the ECU harness connector out ofthecaddy holeif you free the ECU caddy leaving all other wiring in place. You can remove all the wiring too if you wish. I have pics in my( DTT TCFI 2 arrived) post with the caddy semi out and full out. Some of the info in there may help you, or not. Removing the battery tray also allows very good access to things and is easier to fully remove then the ECU caddy.
I think i finally got it in there. the corner of one of the connectors is about 3 or 4 inches from the motor you think that will hurt anything and i couldnt get that middle allen screw in there there where too many wire in the way i hope it still holds on there.
Here is how I have mine and it takes patience to get it there
extremely tight fit
WillieC
ORIGINAL: bobby5
OK guys sorry bout all these questions but i did a search and couldnt find anything that would help get my fuel pak to fit under the cover. Can someone please help me this is the only thing i have to do and im done. It looks impossble to get to fit
extremely tight fit
WillieC
ORIGINAL: bobby5
Thanks Willie ... thats a great help for fitting mine !
