Craftsman Yellow Jack
Old Oct 19, 2013 | 06:49 AM
tcatnat's Avatar
tcatnat
Is this the same Craftsman jack that can be modified to fit the Dynas? I have the Harborfreight yellow jack and did the modification and it works fine.n There are several threads here showing how to do the mod.
Old Oct 19, 2013 | 09:00 AM
spyderwebb's Avatar
spyderwebb
I've got an original HD lift (red one, with two 1.50" wide lift braces that are 14" apart), I bought when I had my 96 softail.
To make it work I purchased the Dyna adapter kit and it works fine. The kit comes with 4 pieces (supports) that temporarly clip on to the frame in the appropriate location to protect the pan and level the lift points.
Other than doing a few practice runs to figure the best placement area..and best technique for a one person lift, it works great.
$25 well spent if you ask me
Old Oct 19, 2013 | 10:06 AM
heckfrozeover's Avatar
heckfrozeover
I've got the Craftsman Professional yellow jack and it works fine on an FXDX using the adapters. I've had 950lb full dressers on the yellow jack, and it's quite solid. The aluminum does flex, allowing the bike to rock a bit (the front and back, not side to side), which at first feels unstable, but that's deceptive. It's actually very stable, and I've sat on bikes with them strapped to the lift without issue.
Old Oct 19, 2013 | 10:52 AM
ExDucRider's Avatar
ExDucRider
This one here is enough to scare me.
https://www.hdforums.com/forum/dyna-...-adapters.html
Old Oct 19, 2013 | 06:37 PM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
Yeah my black widow scissor jack I bought from e-bay worked great on my Sportster, but not quite as good on the SG. Its hard to find a good balance point and still maintain stability.
Old Mar 10, 2015 | 06:55 PM
Noteware's Avatar
Noteware
2nd Gear
some on this forum attest to the yellow craftsman jack being used on a dyna without the adaptors, and some say the adaptors are necessary. Will I need the adaptors if I buy the yellow jack for a 2009 Dyna Superglide ?
thanks,
Mark
Old Mar 10, 2015 | 07:23 PM
ynots's Avatar
ynots
thanks,
Mark
If the lifting arms are as narrow as the ones on the red jack you will
Old Mar 10, 2015 | 07:26 PM
steve5109's Avatar
steve5109
Yes you will need the adapters. The yellow lift will not work with out them.
Old Mar 11, 2015 | 07:51 AM
Noteware's Avatar
Noteware
2nd Gear
thanks.
Mark
Old Mar 11, 2015 | 05:14 PM
Ricketts's Avatar
Ricketts
Me = Yellow jack plus adaptors.
Synstars
Oct 26, 2019 11:34 AM
128auto
Jun 23, 2012 12:24 PM
davedyna
Oct 24, 2008 08:24 PM
n.o.yat
Feb 27, 2008 05:12 PM
Muddyape
Dec 9, 2007 11:36 PM
