Heel Rest or Mid Pegs
Old Oct 22, 2013 | 03:12 PM
LosFire313's Avatar
LosFire313
6th Gear
Originally Posted by blueangel73
I have forwards with the DK Customs Heel Rest and Mids, It might seem a little over kill, but I use the hell out of all of them when I ride long or short distance. I did modify my mids to use a shift lever peg and not a full length peg.
blueagnel That set up you have...thats what i would do! How did you get a shift lever peg to work as a full length peg??
and I cant find the part number the is the bracket for the mid mounts, do you know where i could find them?
Old Oct 22, 2013 | 03:15 PM
LosFire313's Avatar
LosFire313
6th Gear
Originally Posted by DK Custom Products
Here is how one of our customers has theirs set up. We hear nothing but good things about the heel rest. It does reduce the lean angle some.... but its not drastic. It really depends on how you angle it. Check out the special we have going on in my signature right now...... (hint, hint, cough, cough)
Thank you for the shameless plug I think i will order the heel rest kit especial since there is a special happening
now to pick out shift level peg DANG too many choices
Old Oct 22, 2013 | 03:33 PM
DK Custom Products's Avatar
DK Custom Products
Sponsor
Well, I hate to throw out another "shameless plug", BUT , since there is a special going on and everything.... You can check out our shifter peg.....
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
Old Oct 22, 2013 | 04:08 PM
Reindeer's Avatar
Reindeer
Reindeer - What angle do you have your heel rest? I hear they drag often
I've got them at maybe a 45 deg angle relative to horizontal. You can see them in my sig pic if you look real close. Yes, they do drag occasionally. If you're dragging your pegs now, you'll probably won't like the heal rests.
I have the Kuryakyn stirrups. They were on the bike when I got it. The DK ones look a little smaller, might be better for ground clearance but the Kury ones have a pretty large platform.
Old Oct 22, 2013 | 10:02 PM
DoomGloom's Avatar
DoomGloom
I installed the reduced reach forward control brackets from HD with the heel rests and its the best of both worlds.......the kit brings the controls back about an 1.5" and up just a little bit so I can still lean the bike over without grinding the heel rests so much
Old Oct 23, 2013 | 05:59 AM
blueangel73's Avatar
blueangel73
The bike came with the mid setup stock, after I installed the forwards, I removed all the unneeded hardware and reinstalled the mounts. I then took the stock pegs and chopped it up, drilled and tapped a hole in the pivot part to receive the shift peg bolt and bolted it to gether and installed it on the mount. There is plunty of support to stand on, and it doesn't stick out where it would get in your way when your feet are on the ground. I am sure you can find some take off mid mounts on here or on eBay pretty cheap.
Cut off at red line, grind down to blue line and drill and tap at green location.
Old Oct 23, 2013 | 07:08 AM
Eugene18111976's Avatar
Eugene18111976
5th Gear
On a long journey (without ol), i use passanger pegs to rest my legs. Really helps.
Old Oct 23, 2013 | 10:22 AM
zencaptain's Avatar
zencaptain
I've thought about the adding stirrups on mine too, but just couldn't find any I really liked. The Kury option is the one the closest I've gotten, just not thrilled of the look. I did put a 2"extension on and it did make me more comfortable.
I do dig blueangles idea a lot.
Nice bike color by the way.
Old Oct 23, 2013 | 02:33 PM
LosFire313's Avatar
LosFire313
6th Gear
zencaptain - Yes I love the color, i think its the best
Blueangel - THANKS for that quick break down
DK custom - Thanks for all the great products
Thanks guys for all the great feed back
Old Oct 24, 2013 | 04:37 PM
okbill's Avatar
okbill
My WG came with heel rests already installed. I had to adjust them for me but I like them.
DynaWide42
Mar 11, 2010 09:09 PM
hollowpoint
May 27, 2009 07:48 PM
Boneyard Blue
Dec 15, 2008 01:32 PM
Hounds2
Sep 15, 2008 02:56 AM
hard_head
Jul 27, 2005 10:24 AM
