Triple tree swap
Old Nov 15, 2013 | 04:34 PM
G-Lock's Avatar
G-Lock
Default Triple tree swap
So I'm finally swapping out my wide glide trees for fat bob trees. Anyone ever remove the front forks from the trees and not take off the front tire,brakes and fender? In other words just remove the front forks from the trees as a unit. I'm thinking my only problem might be jockeying the front handlebars around to accommodate the front brake movement, or maybe my jack won't lift the bike high enough to get the tube out of the lower tree. Any ideas?
Old Nov 15, 2013 | 05:12 PM
SuperFastGlide's Avatar
SuperFastGlide
pretty easy to just pull the front wheel
Old Nov 15, 2013 | 05:20 PM
G-Lock's Avatar
G-Lock
Yeah, I was just thinking if I pulled it as a unit I wouldn't have to remove the caliper, front axle and fork lower dropouts and fender.
Old Nov 15, 2013 | 07:01 PM
SuperFastGlide
you can do it but i would pull the caliper and let it hang if it was me
Old Nov 15, 2013 | 11:08 PM
HSB's Avatar
HSB
Its doable but its much harder on the reassembly, just take your time and pull it apart less chance of scratching or messing something up..
Old Nov 16, 2013 | 01:38 AM
G-Lock's Avatar
G-Lock
I got the forks taken out in one piece. It was actually really easy. I guess my brake line being long really helped. Got it done in about 45 mins, and was surprised that it only raised the front end by 3/4". I pushed 1/4" of the fork tubes up above the top tree. Gotta take it for a ride tomorrow.
Old Nov 16, 2013 | 08:59 PM
mojo6677's Avatar
mojo6677
You still selling the wide glide trees?
TN07FXSTC
Nov 29, 2016 10:04 PM
gordo68
Jan 2, 2012 12:19 PM
WVleo
Apr 5, 2010 05:36 AM
JohnnyBravo
Jan 27, 2010 11:38 AM
PoBoyGlide
Feb 11, 2008 11:44 AM
