Switchback front end ?
Old Nov 17, 2013 | 12:12 PM
rauchman's Avatar
rauchman
Default Switchback front end ?
Bought a Switchback recently and want to do something about the less than desirable front brakes. I've looked into upgrading the caliper on the one rotor, but would prefer to have dual discs w/ good calipers.
I think I remember reading somewhere that the Switchback uses an FL front end. Does this mean that if I get a Road King right side lower fork, a Road King front rim, rotors/calipers, possibly a new master cylinder and new brake lines, I can convert my bike to dual disk front brakes? I'd like to be able to use the HD branded Brembo's.
Would I be correct in assuming that the front tire size would be different?
If so, would I need a new fender?
Thoughts please.
Old Nov 17, 2013 | 12:25 PM
Chinashop bull's Avatar
Chinashop bull
The front end is unique to the FLD. It has an FL style headlight nacelle. Nothing else.
Want better brakes, change the pads, or a get 6 pot caliper.
I run a 16" wire wheel with 500-16 vintage style rubber on my FLD with clearance to spare.
Old Nov 17, 2013 | 04:32 PM
FBinSoCal's Avatar
FBinSoCal
what's a good brand of pads to change to?
I'm still running stock
Old Nov 17, 2013 | 04:59 PM
Chasespeed's Avatar
Chasespeed
EBC is a good start.
Chase
Old Nov 18, 2013 | 03:53 AM
1HD1C's Avatar
1HD1C
EBC Pads.. number of the guys on the switchback site are running them
and have posted nothing but great things about the difference over stock
The EBC part numbers are:
Front FA-457HH
Rear FA 458HH
Old Nov 18, 2013 | 03:59 AM
Chinashop bull
Lyndall Gold Pads.
Old Nov 18, 2013 | 08:15 AM
rauchman's Avatar
rauchman
Great info. Thanks!
Old Nov 18, 2013 | 08:03 PM
Carl '69's Avatar
Carl '69
You sure? I can't imagine the Moco changed much inside the 41mm fork. Should be able to use 41mm lowers off a dresser, no sweat, as long as he also uses a FL Touring front fender, vs. a FL Softail fender, as the mounting tab heights are different.
I'd try a braided line & good pads first & see if that works for you. Don't necessarily believe a Harley really needs dual discs, as opposed to, say, a big-bore sportbike. A quality, single, 4-piston caliper, good pads & a braided line will be a night & day difference over stock. Don't spend a bunch of money you don't need to, unless/until you're sure you need it.
Old Nov 19, 2013 | 06:13 AM
Chinashop bull
Totally different setup. Check out the expand view. One leg runs standard damper rod in oil, the other is a cartridge insert. Also, the forks are spaced apart different to any other Harley. No parts interchange.
http://partsfinder.onlinemicrofiche....-FORK-ASSEMBLY
FLD's have braided lines stock.
Old Nov 19, 2013 | 06:49 AM
rauchman's Avatar
rauchman
Are you sure about that? I have an FLD and, unless they are rubber coating the braided steel line, I don't think mine has braided lines.
