Need Windvest help!
Old Mar 14, 2007 | 07:46 PM
akflyer's Avatar
akflyer
Default Need Windvest help!
I am looking for some advice from you Windvest owners out there. I have a 14x16 Windvest on my '07 Bob. No matter how I have tried to adjust it I still get a large amount of buffeting. I am 6'1" with forward controls and a stock seat. Has anyone found a good combination of height and tilt that worked for them? I would like to tryeverything I can tomake this work better before I scrap it and go to something else. Thanks!
[IMG]local://upfiles/15755/2EFFCBA0D6AC41B391625E424715CAAC.jpg[/IMG]
Old Mar 15, 2007 | 03:53 AM
TOMMAY's Avatar
TOMMAY
Default RE: Need Windvest help!
Set your height to where you can easily see over the top of the shield. You've got an inch of adjustment in the windshield and an inch or so by reversing the handlebar clamps. The tilt of the shield makes a difference. Start with the front of the shield flowing pretty much with the line of the fork tubes and adjust forward or backwards from there. WhenI first got mine I was sick that I'd spent that much money and had such buffeting but I spent a few miles with an allen wrench and kept tilting back and forth til it went away.
A lot of the turbulance is coming from below.A small bag at the base of the shield on the inside helps. A tank lift helps a lot. Keep in mind that the Wind vest is not gonna keep that much wind off your face,it stops the big blast on your chest at high speeds.Tighten your helmet down good,hold the right strap while you snug the other side down real good.Reversing your mirrors keeps a good bit of wind off your sides but takes some getting used to since you're looking under your armpits to see behind.
I've often ridden for hours at 85 to 95 with the Windvest,almost seems the faster you go the better it feels,may have something to do with the lip at the top of the shield. Again,the tank lift probably makes the biggest difference in the airflow from below.
Don't give up,it will work and work fine. I've ridden many five to eight hundred mile days in comfort with the little shield and it looks better than any other shield you can buy.
Good Luck
Tom
Old Mar 15, 2007 | 08:37 AM
ULTRA Gramps's Avatar
ULTRA Gramps
A 2 inch tank lift seems to have helped mine.
Old Mar 15, 2007 | 12:02 PM
Stanger's Avatar
Stanger
Good luck! I have a windvest sitting on the bench and a Memphis Shades on the bike, all due to the same situation you are talking about.
I do wish you luck though.
Old Mar 15, 2007 | 05:22 PM
akflyer's Avatar
akflyer
Thanks for the comments! Which height adjustment level do you have yours on? Did you find tilting in or out to be most beneficial? I'm just looking to find the best place to start tweaking.
Old Mar 15, 2007 | 07:00 PM
Bobber Jay's Avatar
Bobber Jay
Simple solution ......
# remove the wind vest.
# walk to nearest window / door.
# throw wind vestwith as much might as you can muster.
# join the men and just hold tighter.
-=BJ=-
Old Mar 15, 2007 | 08:53 PM
stbob's Avatar
stbob
Ha ha ha thats funny^^^^
Old May 27, 2007 | 12:01 PM
JBaker421's Avatar
JBaker421
Big Kahuna HDF Member
Fork bag.
Old Jun 11, 2007 | 02:50 PM
07fxdl's Avatar
07fxdl
Stage IV
Stanger,
Do you still have the Windvest? Want to sell it? Is it 14X14 or 14X16? Clear or smoked? Which model number?
Thanks,
Bill
Old Jun 11, 2007 | 03:42 PM
Punty's Avatar
Punty
ORIGINAL: Stanger
Well if either of you guys are instersted in sellinig please let me know
thanks
kmoberlypilot
Jun 16, 2014 06:49 AM
hogcowboy
Apr 16, 2013 10:41 PM
MiniWolf
Oct 10, 2012 09:52 AM
frozensoul
Sep 12, 2012 03:25 PM
Danthern
Aug 8, 2010 08:41 PM
