Dyna Pulley Question
Old Dec 11, 2013 | 03:07 PM
Romprunner714's Avatar
Romprunner714
Default Dyna Pulley Question
I tried to find my answer on search but could not find an answer.
I want a lot more low end power on my 07 fxdb. Whats the highest Tooth Count rear pulley that would fit my bike?
(Changing the front pulley is out of my league and out of my budget to get done at a shop.)
I believe stock rear is 66. Is there a 75 tooth? would i still be able to hit 100mph after doing this? Thanks
Old Dec 11, 2013 | 03:11 PM
rooti's Avatar
rooti
Here is a post you want to read through:
https://www.hdforums.com/forum/dyna-...y-install.html
Old Dec 11, 2013 | 03:14 PM
02fx4dude's Avatar
02fx4dude
Pulley from an 06 Dyna is 70 tooth and will fit, but requires replacing the belt, which requires pulling the primary, then you might as well do the front pulley as long as you have it apart.
Old Dec 11, 2013 | 05:30 PM
Guest
Guest
Posts: n/a
man, that fender really does change the whole look of the dyna, genius!
Old Dec 11, 2013 | 08:14 PM
8541hog's Avatar
8541hog
This is correct. For reference a 2 tooth rear pulley change is roughly equivalent to a 1 tooth front pulley change.
You won't get much at all changing the rear without changing the belt.
Old Dec 12, 2013 | 06:00 AM
02fx4dude's Avatar
02fx4dude
Thanks.
Genius! LOL, can't take credit for the idea.
Old Dec 12, 2013 | 12:09 PM
nevil's Avatar
nevil
Just remember that whichever way you go to change your final drive ratio you will have to figure out what 100 mph really is, since your speedo reading will be off. I know you're trying to figure out what to do but it will affect the speed that the gauge is telling you.
Old Dec 12, 2013 | 01:52 PM
JRK5892's Avatar
JRK5892
i run a 30/70 set up, rips!
Old Dec 12, 2013 | 02:20 PM
HD Pilot's Avatar
HD Pilot
You should get away with a 2 tooth change to your rear pulley without changing your belt. May not be a big enough change for you, only ~ 3%.
2006 International Dyna Pulley = 68T
#40535-06 Black
#40537-06 Silver
Bruce Hunt
Jan 2, 2022 02:48 PM
Bruce Hunt
Sep 18, 2020 02:40 PM
jsbridgew
Jun 20, 2012 04:06 PM
LouEyez
Oct 5, 2010 07:20 PM
dope_man_21
Aug 2, 2009 06:24 PM
