Is it Difficult to Replace a Primary Cover on FXDWG?
paint on it (wrinkle Black). Looks better...but, I'm going to replace it.
I'm not mechanic, but would like to do it myself. Is it hard to do?
I dont want to scratch anything again. Be safe!
Like already mentioned I would get a new gasket, although I have reused them before in a pinch.
1. There is a drain plug directly under the clutch basket that takes a 5/8" wrench. Remove that and drain into a container.
2. Remove the Torx head bolts from the Derby cover as you will have to reinstall that onto the new primary cover after installing and filling with oil.
3. Remove all of the socket head fasteners around the perimeter of the primary cover.
4. Remove primary cover.
5. Clean mating surface of inner primary and install gasket.
6. Install new primary outer cover and torque to 108-120 in/lbs.
7. Pour in the proper amount of HD primary lubricant through the Derby cover. It should just be to the bottom of the clutch diaphragm spring (approx. 1 qt.).
8. Install the Derby cover with new gasket and torque to 84-108 in/lbs.
Ride and enjoy. Try not to scratch it this time.
Mike.
Just may be that he is not familiar with HD's. Was a bit of a learning curve (still learning) for me coming from sport bikes.
OP: Go for it bro, even if you screw up you are still learning!
+1
