Pitbull jack
Old Jan 7, 2014 | 09:13 AM
e.mic.b's Avatar
e.mic.b
6th Gear
Default Pitbull jack
Hey all, I have a chance at a 1000lb Pitbull jack for 200, new condition. The seller says its pads are 17.5 inches long and 17 inches apart. Will this fit my 2010 street bob? Any help and time is appreciated...thanks....e
Old Jan 7, 2014 | 10:08 AM
WMX124's Avatar
WMX124
Unless it is the stand specifically designed for a dyna, it wont work.
Search for the sears jack modification. Cheaper than $200 and works flawlessly on my street bob.
Old Jan 7, 2014 | 10:11 AM
e.mic.b's Avatar
e.mic.b
6th Gear
Thanks a ton, solid advice... Was leaning that way.
Old Jan 7, 2014 | 11:16 AM
boro's Avatar
boro
Wait! My J&S jack has a spread of 17" and fits perfectly. The supports are only about 2" wide, but there is plenty of room for them to be a little wider.
Old Jan 7, 2014 | 03:34 PM
PaiN's Avatar
PaiN
Here's a good vid to watch on the Pitbull
Old Jan 7, 2014 | 06:40 PM
rooti's Avatar
rooti
it will work..no such thing as a dyna jack....where did you come up with that one?
Old Jan 7, 2014 | 06:51 PM
Campy Roadie's Avatar
Campy Roadie
Pitbull has a standard lift and one specifically for Dynas. My guess is that's where "he came up with it". The difference is the lifting platforms.
Old Jan 7, 2014 | 08:59 PM
WMX124's Avatar
WMX124
http://www.pitbullmotorcyclelifts.com/FAQ.html
Direct quote from Pitbull website:
"What is the difference between the Dyna lift and the Standard lift?
Before we came out with this new Dyna lift, there was no other way to pick up Dyna's (Wideglides, Superglides, Lowriders and Dyna Sports) made 1999 to present without the use of adapters because the tranny oil pan on these bikes hang down below the frame. Our new Dyna lift is pretty much exactly like our standard lift other than we made the lifting rails allot wider apart to compensate for the tranny oil pan, it actually spans the oil pan and the kickstand so nothing hangs down in the way of the Dyna series lift and you can simply roll the lift under and jack up the bike. You do not need to use any adapter on this lift. This lift will also work on ALL Harley Davidson makes and models including all customs / choppers and some metric bikes."
What do you use?
Old Jan 7, 2014 | 09:02 PM
Iceman24's Avatar
Iceman24
Measure the spread on your oil pan (underneath)...if less than 17", I'd get the pitbull. Steal for $200...JMO.
Old Jan 8, 2014 | 03:03 AM
e.mic.b's Avatar
e.mic.b
6th Gear
Thanks fellas, some good info to be had here..
