Wiring under rear fender
Old Jan 18, 2014 | 08:10 PM
machm1969's Avatar
machm1969
Default Wiring under rear fender
I'm going to be removing my rear fender for repaint soon due to some paint damage. When I painted it initially I bought some of the "weatherstrip tunnel" that's stuck to the bottom of the rear fender. The stuff the dealership sold me was smaller than original and a real PITA to pull the wiring through. Does anyone know somewhere else to get that stuff?
Thanks,
Matt
Old Jan 19, 2014 | 08:56 AM
Danish-chopper's Avatar
Danish-chopper
Cant you reuse the original/old one, and just glue it on?
Old Jan 19, 2014 | 11:13 AM
JRK5892's Avatar
JRK5892
personally i would never run wiring under the middle of the fender, ever! what a **** poor design from HD. If you run a search you will see what i do on dyna's i run shrink wrap around the inner fender rails and feed the wire though there. then you never have to worry about the tire rubbing though, so much cleaner... here is a shot from when i wired up my last fender mod
Old Jan 19, 2014 | 11:24 AM
chris h.'s Avatar
chris h.
I did the same on my bike to have clearance for my air ride. No problems so far.
Old Jan 19, 2014 | 11:30 AM
128auto's Avatar
128auto
You can reuse the tunnel and use urethane adhesive, I have replaced my fender 2 yrs ago, still holding up. If you are planning to lower the bike, you might want to do what Joe(JRK5892) just said.
Old Jan 19, 2014 | 12:12 PM
stilup's Avatar
stilup
can't buy it new? the real stuff?
Old Jan 19, 2014 | 06:19 PM
ramhunter9's Avatar
ramhunter9
Who needs wires.
Old Jan 19, 2014 | 06:35 PM
Flinter's Avatar
Flinter
You can buy a new harness for about 50 bucks. For that money, I wouldn't worry too much about how I was going to tape the old one back in place.
Old Jan 19, 2014 | 06:43 PM
machm1969's Avatar
machm1969
You can buy new stuff from the stealership, but in my case all they had was a little smaller than what came on the bike, made it a PITA with the wiring, almost like pulling wires through the handlebars. I like Joe's idea, I couldn't believe how HD ran the wires from the factory when I pulled it apart. Joe, how do you attach the wires the fender or strut?
Thanks,
Matt
Old Jan 20, 2014 | 07:34 PM
machm1969's Avatar
machm1969
I spoke with a different guy at the stealership, seemed to know a little more. The harness for my WG is $140, so I'm out on that. HD does sell a kit, they call it conduit. The part# is 70540-02, it's $8.99. I'm going Joe's route though, seems like a better idea.
Thanks,
Matt
