Front brake buzzing sound
Old Feb 8, 2014 | 09:26 AM
fxwoody's Avatar
fxwoody
Just don't ever brake! lol .....mine does the buzzing too, as for the vibration, get to a steady speed and gently apply pressure to the brake lever, if you feel a small vibration in the lever, rotor could be warped.
By turning on left side, the rotor (normally floating ones) have tendency to vibrate because of the weight it apply on the caliper pads since it moves on the bushing of the support attached to the hub. A loose bushing rotor bushing or worn out can do this! If you have spokes rims, check them to make sure none are loose
Old Feb 8, 2014 | 12:15 PM
nevil's Avatar
nevil
Welcome to the forum.
The noise is normal.
Brakes are for quitters, anyway.
Old Feb 9, 2014 | 05:15 PM
Junkster's Avatar
Junkster
Not sure about solid rotors. I would assume the cooling holes may cause some clicking.
Old Feb 10, 2014 | 12:03 AM
Gommee's Avatar
Gommee
Devil's Advocate
Buzzing sound is normal, my 07 has done it since new. Still running original pads. Gas is on the handle bar, just twist it!
Old Feb 10, 2014 | 10:23 AM
upflying's Avatar
upflying
My brand new bike front brake makes a buzzing frying pan sound. Normal.
Old Feb 10, 2014 | 10:31 AM
Sharkman73's Avatar
Sharkman73
Normal.
Alleyn
Feb 8, 2015 09:47 AM
Edywazoo
Wheels/Tires
Jul 19, 2013 07:25 PM
ken b
Oct 29, 2011 03:01 PM
20STREETGLIDE08
Jun 14, 2010 09:09 PM
smittyp83
Sep 9, 2006 01:42 PM
