2012 wideglide Dyno #
Old Mar 1, 2014 | 07:54 PM
AbBoy's Avatar
AbBoy
or not
Old Mar 1, 2014 | 08:05 PM
AbBoy's Avatar
AbBoy
Old Mar 1, 2014 | 10:41 PM
AbBoy's Avatar
AbBoy
Here is the dyno sheet
Old Mar 2, 2014 | 07:20 AM
vdop's Avatar
vdop
Actually looks really good. Nice and smooth, not choppy, no dips, same with afr. Looks like they know what they're doing. If they were able to get the wide open runs that good there's a good chance the rest of the tune was done right too. If it feels good and seems to run good on the road I'd leave it alone. Looks like there might be some clutch slip, that spike at 4300 is the clutch finally hooking up. Usually only see that on 96" bikes with their weaker clutch spring. You might want to consider a little heavier spring but nothing to really worry about, it probably can't be felt on the road.
Old Mar 2, 2014 | 10:26 AM
AbBoy's Avatar
AbBoy
So hp limited to the cam selection and pipes i guess. i've been told i should have went with the se204 but i just let the dealer install what they recommended
Old Mar 2, 2014 | 01:22 PM
AbBoy's Avatar
AbBoy
The only thing that makes me question the tune is my father inlaw had his 2012 street glide with the 120r dyno tuned there and they cam out with 104hp .now correct me if im wrong but that is extremly low. Now they did mention it was a brand new dyno ,not sure what type
Old Mar 2, 2014 | 05:17 PM
PistolPete83's Avatar
PistolPete83
Vdop..can you recomend a good dyno tuner here in CT...i also have a gsxr 750
Old Mar 2, 2014 | 06:02 PM
Chasespeed's Avatar
Chasespeed
Depending on where in CT, I might be interested as well... I'm just over the line from Stafford Speedway....
Chase
SA66
Engine Mechanical Topics
19
Mar 23, 2019 11:43 AM
Zener
Nov 2, 2013 08:08 PM
bigzig89
Mar 28, 2013 12:17 AM
crash1969
Exhaust System Topics
May 30, 2012 07:52 PM
02 king kong
Jan 26, 2008 09:37 PM
