2012 FATBOB fork lock question
Old Mar 2, 2014 | 08:48 AM
mleugner1974's Avatar
mleugner1974
Default 2012 FATBOB fork lock question
I did some searching but came up short.
Can the fork lock on a 2012 FXDF be adjusted?
Mine does not go into the locking hole.
Does every one use this feature, it seems like a good thing to me but as I just got this bike it is something I have only recently come accross, once the weather smartens up I will be taking it in and getting the dealer to look at but just wondering if its a fix I could do.
Thx
Old Mar 2, 2014 | 09:23 AM
maddghost's Avatar
maddghost
yes that is an easy fix. Just carefully peel the lock/unlock adhesive decal off so you can re-apply it later. Under that you will see a couple of d-shaped holes. these come loose sometimes or perhaps you or someone else turned the fork lock at the wrong moment. Stick one prong of a long nose plier into each hole and loosen a bit then turn your lock back where it belongs and tighten the mechanism and reapply your decal. I may not remember the process exactly but It's all in the manual dude!
Old Mar 2, 2014 | 10:32 AM
mleugner1974
OK thanks, I looked in the manual but must have missed that. I will give that a shot when i get home. Man I wish spring would get here...-37 when i went to work....
Old Mar 2, 2014 | 12:14 PM
08fxdf43202's Avatar
08fxdf43202
My 08 does the same thing. All that's needed for mine is a jiggle on the bars as I turn the key in the lock.
Old Mar 2, 2014 | 12:34 PM
mleugner1974
that was my first attept at fixing, than upon further inspection, almost laying under bike, it appears i am almost 3/4 of a hole out...
Old Mar 2, 2014 | 12:56 PM
maddghost's Avatar
maddghost
his is not hard to get in it has rotated in place
That likely happened when the lock was engaged while the fork wasn't in the right position. then it's kind on stuck so we pull the handlebars and all is good until we need to use the fork lock again.
Old Mar 3, 2014 | 11:01 AM
mleugner1974
thanks maddghost, i got my lock fixed up last night, easy easy, just like you said.
thanks again
gseely
Feb 20, 2023 08:42 PM
47909Rider
Jul 2, 2013 07:55 AM
chorndawg
May 10, 2012 10:08 AM
Handycam
Apr 11, 2011 07:00 PM
madcitycustom
Sep 18, 2006 11:20 AM
