Preload adjusters
Old Mar 10, 2014 | 04:44 PM
spankdog's Avatar
spankdog
Yea for sure. Springs are pretty cheap. To be honest, I just figures at 195-200 lbs Im pretty much in the middle of the average HD rider weight for stock springs. I did try to mess with the sag when I intstalled my progressive drop in lowering springs but those things were so stiff it would have been damn near impossible to get it right. I ended up throwing the stock springs back in and the ride felt good so I left it alone. I do have a manual though so if you want I cant try to look up the sag specs for you.
Old Mar 10, 2014 | 04:53 PM
07bobber's Avatar
07bobber
im running the speed merchant adjuster and I gotta say I love em, I can adjust/ tune the front with a quick turn of a wrench. yes they are expensive but they are worth it to me. id rather make a small adjustment than tearing it apart and cutting or adding to the spacer etc
Old Mar 10, 2014 | 05:39 PM
rooti's Avatar
rooti
As an example, if you had 6 inches of total suspension travel, you want to set your sag to 3 inches. That means your body weight and normal riding gear should compress the front forks to half of it available travel.
Can you tell me where you got your information? Everything I've ever read says that on a street bike your front sag should be set at 33% or 1/3rd of the travel. I've never heard of using half your travel for sag on any bike made.
Most dyna have 4 1/2"-5" of travel, and 1.5 works pretty good.
Old Mar 10, 2014 | 05:57 PM
spankdog's Avatar
spankdog
I would get the Speed Merchant ones over the RSD ones any day. Mostly just because RSD stuff is so over priced that I feel compelled not to buy from them just on principle. lol. And the adjusters ARE cool. Even if you only need them once I think its worth the money just so you don't have to remove the caps over and over. Those things are a pain in the *** and its almost impossible not to nick or gouge the caps unless you wrap the **** out of them with tape or use and aluminum wrench. Im not rich but little upgrades like that are fun and cool even if they aren't completely necessary. Personally I think the stock forks aren't worth the effort but that's just me. Im also the dumbass that spends **** loads of money trying to make my 8000lbs diesel 4X4 fast, so I understand the urge to tinker and mod and improve stuff. If I "were" to try to mod the stock forks I would go with Traxxion straight rate coils, SM adjusters, and Ricor Intimidators. Short of a cartridge install or straight up USD fork set up, springs, adjusters, and Intimidators would be a pretty sweet and affordable set up.
Old Mar 10, 2014 | 06:01 PM
spankdog's Avatar
spankdog
Sorry. I was just using those numbers as an example of sag. I didn't mean to imply that half of the total travel is where you need to set it. Unless you are jumping your bike youre always going to want more compression travel than extension travel. Youre right, for our bikes they say to set sag at 1/3rd of the total travel. I should have worded my reply different. Sorry about that.
Old Mar 10, 2014 | 06:06 PM
izzyryder's Avatar
izzyryder
Sag can be between 1/4 to 1/3 suspension travel. I was initially against the preload adjusters but gotta say they are great.
Old Mar 10, 2014 | 06:07 PM
izzyryder's Avatar
izzyryder
Also my vote is for the speed merchant adjusters. Least with them they have markings in case you don't remember how many turns your at.
jcsurf
Jan 5, 2015 07:06 PM
cripple
Mar 18, 2013 01:04 AM
1HD1C
Jun 27, 2012 06:45 AM
