T-Bars have arrived - Install help
Old Mar 17, 2014 | 06:18 PM
STREET BOB JOE's Avatar
STREET BOB JOE
Default T-Bars have arrived - Install help
So they have arrived! Look bad *** and I am looking forward to installing them. So my first question is do I disconnect the wiring from under the neck where the big mess of wires are or from the switch housings? I have done some google searched and haven't had much success finding an install video on a newer street bob. 2013 or 2014. Any links would be great. Thanks!
Old Mar 17, 2014 | 06:42 PM
JMummery's Avatar
JMummery
I undid the plug from the neck. Not too bad one on the right and two on the left I think or vice versa. Not to bad at all
Old Mar 17, 2014 | 06:57 PM
jdub099's Avatar
jdub099
Do you just tug the harness a bit out of the neck to get to the plugs? Or do you have to remove the tank?
Old Mar 17, 2014 | 07:04 PM
myugly88's Avatar
myugly88
WE WANT INSTALL PICS!!! Lol!!! please????
Old Mar 17, 2014 | 07:45 PM
JonnyLew's Avatar
JonnyLew
lucky you..mine will be here tomorow or weds..pretty well a month since ordering so im getting pretty anxious
Old Mar 17, 2014 | 08:12 PM
glock35's Avatar
glock35
I just popped out the rubber plug at the neck and then it was really easy to pull the connectors out and disconnect them. Pretty straightforward job.
Old Mar 17, 2014 | 08:40 PM
monster715's Avatar
monster715
Pull the plugs out of the neck. Unbolt the take and slide it back a few inches (careful not to scratch your rocker covers or tank). On mine there's a little plastic piece under the backbone, I'm not sure that the new bikes are still this way, pull that and it will help with getting the harness out and getting it back in. Pull the rubber grommets and work the plugs out, might havta pull a little from one side and then a little from the other. They will come out, piece of cake!
Old Mar 17, 2014 | 09:24 PM
JMummery's Avatar
JMummery
exactly the same idea for a 14 street bob except the plastic piece, no idea what that is. Undo the grommet and pull out the harnesses and unplug
Old Mar 18, 2014 | 10:18 PM
STREET BOB JOE
For the brake side will the brake cable be okay just hanging there? Will brake fluid leak out if its upside down?
Old Mar 18, 2014 | 10:24 PM
Slvr764's Avatar
Slvr764
[QUOTE=STREET BOB JOE;12458735]For the brake side will the brake cable be okay just hanging there? Will brake fluid leak out if its upside down?[/
You would need to bleed the brakes anyway if you disconnected that line so it's irrelevant.
