Springer and 16" wheel question
Old Mar 23, 2007 | 07:37 PM
gorilla's Avatar
gorilla
Default Springer and 16" wheel question
I started to title this thread, "Springer and 16 inchwheel on a BOB"just to go along with the recent threads, but I decided against it. My question is this. I want to put a springer on my SB. But I don't want the 21" wheel. I want to run a 16" wheel so I have a taller side wall. But will a stock length springer work? Or do I need a +2" or something? I want my bike to sit level without having to mess with the back suspension. Any input would be appreciated. kpreese, do you have any advice?
Old Mar 23, 2007 | 07:57 PM
metal_mike's Avatar
metal_mike
Default RE: Springer and 16" wheel question
i believe the springer classics come w/ a 16" wheel...dont think you'll have a problem there...
Old Mar 25, 2007 | 04:42 PM
gorilla's Avatar
gorilla
So one reply is all I get? Thanks metal_mike for your response.
Old Mar 25, 2007 | 04:55 PM
metal_mike's Avatar
metal_mike
no prob....if you re-read kpreese's original thread on his install...he said there was quite a bit of machining[grinding] to be done on the lower tree and you'll lose the fork lock...
Old Mar 25, 2007 | 05:05 PM
kpreese's Avatar
kpreese
I would start specifically with the Heritage front end.With a little luck,it'll be about the same as what I had to do.
I've been toying with trying to get the 19" on mine, but I have zero cash for tinkering at the moment. The springer on the Heritage is actually a different springer as I understand. I think the fork spacing is wider.If that's truethen it*could* cause some problems, but you won't know until you try. No one else is going to have the answers to your questions unfortunately.
What I did was define key areas of potential trouble and then asked VERY specific questions, asked for photos and measurements, etc from a few members via PM. Start with the basics and ask the softail guys if they can tell you the differences in the front ends. Are the fork spacings different? Fork lengths different? Perhaps try to find out how the fender mounts vary, etc.
As I've said before, be happy to help where my experience is useful. Ask me anything, anytime. But you are in uncharted territorylike I was. I can help you, but only so far since you aren't going the same exact place I did. But if you can establish what the differences are between the two springers, you can still use what I've done as a spring board.
Kevin
Old Mar 25, 2007 | 10:26 PM
gorilla's Avatar
gorilla
Gracias! I'm off to the softail section.
Old Mar 25, 2007 | 10:55 PM
voyager1's Avatar
voyager1
ORIGINAL: gorilla
don't leave us, stay with the real men,:LOL.
coma
Dec 8, 2015 11:58 AM
Turret_plug
Jan 21, 2013 08:08 PM
Oldman - New Iron
Aug 31, 2009 09:07 PM
64camo
Aug 31, 2009 12:34 PM
cirhere2
Dec 5, 2008 06:13 PM
