I am in the process of installing a Pro One Signal Bar. The problem is that the light bar only has one wire lead to each turn signal. Does anyone know how to wire the one lead to the stock wiring which has three wires? Will I need a load equalizer?
Hopefully one of the guys that have those installed can answer for you, All I can guess is that you will have one wire that won't be used with that light bar. The pro-one signal bars usesingle filament bulbs verse the stock dual filament bulbs.
Gents, I did get these to work properly. Here is what you have to do.
(1). Only connect the purple wire.
(2). You will need a Badland Load Equalizer III
This should correct any problem of the lights blinking rapidly or the lights just staying on.
Tony @ Pro One was a great help, here is his #. 1-800-884-4173 x: 30
