Installing front signal bar
Old Jan 6, 2008 | 07:00 PM
OscarsSoftail's Avatar
OscarsSoftail
Default Installing front signal bar
I trying to install the pro one turn signal bar on my buddies 93 softail, but there is only one wire coming from the bar, and two from the bike (one accessories for driving lights, and one for the actual blinkers). We cannot figure out how to wire these up so we have a blinking blinker. Thanks for any help. appreciate it.
Old Jan 6, 2008 | 07:56 PM
DR.Greenthumb's Avatar
DR.Greenthumb
Default RE: Installing front signal bar
You should have a left turn and a right turn wire on both the bike and the light bar.Are you trying to use it for driving light too?Seems like it would be too small for that.I had to run a seperate ground wire to the bar,it wouldn't ground itself.I don't think the triple trees provide a good grounding surface
Old Jan 6, 2008 | 08:53 PM
OscarsSoftail
NO, the original signals work as driving lights/blinkers, so there is an accessory power wire and a blinker power wire. When we just hook up the blinker power wire (everything is properly grounded) we get a solid lgiht when the blinker is turned on.
Old Jan 6, 2008 | 08:56 PM
CycleDrider's Avatar
CycleDrider
I had that bar on my WG. There is only one filament in the bulb for each side. So like mentioned above tie your turn signal wire into the light bar for each side and you may need to run a ground wire to the bottom tree somewhere. You won't get a good ground through the bearings on the triple tree. Tape up the accessory light wire or shrink wrap them up.
Joe Carbisiero
Electrical/Lighting/Alarm
May 10, 2019 01:32 PM
KaBar2336
Aug 14, 2017 02:37 PM
lowglide88
Jun 6, 2016 08:48 PM
Mad Bob er
Jan 6, 2008 08:42 PM
jackietan
Sep 9, 2007 07:09 AM
