Customized 06 Super Glide Custom
Just got it back a couple days ago having the new handlebars and all the chrome put on the handlebars, husband and I installed the chrome strip on gas tank and the new V&H short shot exhaust system with the PCIII. Finally got to ride today, the weather was pretty good! Thanks a bunch to JMbear for telling me how to post pics..........yes, you are right John, it was easy.
I've got the exact same handlebar and gauge setup on my 06 Superglide, except Harleygirl81, went one set farther and switched to the hydrolic clutch setup as well. I'll add the part numbers needed to complete the change if your interested. Its a fairly costly setup butits the best looking setup that I was able to find for the Superglide that also included a Tach.I'll add a some close up pics of my setup.
http://i61.photobucket.com/albums/h6.../bars003-1.jpg
http://i61.photobucket.com/albums/h6.../bars002-1.jpg
http://i61.photobucket.com/albums/h6.../bars001-1.jpg
John
I think I'm good for part #s except the speedo housing and mount. Any info on that?
Thanks.
56973-07 CVO handlebar chrome $357.50
67880-94 Boot, reset switch $1.31
67925-04 Tapered mini tach Ga $13.88
67952-96 Gasket, Isolation, M $4.22
67956-96 Screw, Flat socket M $2.41
68953-04 Blackface mini tach $95.74
69853-07 Ring, Tach MTG $14.24
69854-07 Bracket, Speedo Mount $20.74
69855-07 Bracket, Ring, Indic $14.24
69868-07 Retainer, Indicator $2.54
71970-07 Wire Harness Instrument $166.00 at local dealer zanottis will be cheaper
46724-06 Diamondback brake cable $54.35
Total $747.17
I also used a chrome braided wiring housing cover purchased at autozone to cover all of the wires that I had to cut to give it a better look and I also bought a set of the H-D billet riser bolts and a set of chrome banjo bolts when I replaced the brake cable with chrome.
