change duck tail of my WG
Old Apr 8, 2014 | 11:32 AM
Capri87's Avatar
Capri87
6th Gear
Default change duck tail of my WG
hI Guys!
My Wide Glide 2007 have a duck tail and i want change it.
Wide glide fender of 2010 is compatible with my bike? or i need change some things?
Thanks!
Regards
Old Apr 8, 2014 | 11:45 AM
mattVA's Avatar
mattVA
Pretty sure it isn't compatible (wider struts). I think you can get a super glide fender, though.
Old Apr 8, 2014 | 11:49 AM
Capri87's Avatar
Capri87
6th Gear
Thanks.
So and if i change the struts?
super glide fender, but what about year?
regards and thanks
Old Apr 8, 2014 | 11:57 AM
DesertDyna's Avatar
DesertDyna
I recommend you just go to Jpcycles and decide what type of fender you are looking for. Measure the width between your frame struts and go from there.
http://www.jpcycles.com/2007-harley-...rs/rear?Nao=48
Old Apr 8, 2014 | 12:22 PM
SLV's Avatar
SLV
Capri,
The struts are part of the frame and can't be changed without cutting and welding. You'll need a Superglide, Street Bob or Low Rider fender. Anything from '06 and newer will fit. Possibly older but I'm not sure.
Old Apr 8, 2014 | 12:35 PM
dirtdobber's Avatar
dirtdobber
There are lots of fenders available to meet your needs. Just do some research. I think you will find something that will meet what you want.
Old Apr 8, 2014 | 03:08 PM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
I love the look of those duck tail fenders, but to each his own.
Old Apr 8, 2014 | 04:09 PM
Capri87's Avatar
Capri87
6th Gear
Thanks! good site, the problem is the struts, is too long, i would like a short struts..
Old Apr 8, 2014 | 04:12 PM
Capri87's Avatar
Capri87
6th Gear
Yes, but i need a short struts, for the street bob fender for example.. because my WG 2007 has a long struts.
Old Apr 8, 2014 | 08:49 PM
20RoadGlidin's Avatar
20RoadGlidin
Those chrome struts are actually covers. The strut is underneath the cover and is not nearly as long. You're struts are the same as the ones on the street bob, super glide, and low rider.
