mx tbar installed - cable question
Old Apr 11, 2014 | 10:58 AM
iDodgimus's Avatar
iDodgimus
Default mx tbar installed - cable question
10" MX-TBars installed, but I haven't wired everything back together again yet… so far I'm stoked - they feel really comfortable, can't wait to actually ride with them
Anyway….
They're definitely a bit shorter than the stock mini-apes and now my cables seem a bit too long, especially the clutch…
Just by eyeballing them I'm thinking new cables should be -2"
Does anyone have any input, on what size they think, or how to dial in exactly what they should be?
Thanks
Old Apr 11, 2014 | 07:01 PM
coachstorms's Avatar
coachstorms
You could try re-routing them to take out some of the slack before you drop coin on new cables.
Old Apr 11, 2014 | 07:33 PM
Good_Apollo's Avatar
Good_Apollo
Route your clutch cable behind the trees and through the cable hole in the top tree, will make it look much cleaner. Brake and throttle/idle look fine but if you wanted to take out a little slack run the throttle/idle between the trees next to the headlight and back up to the cotnrol
Old Apr 11, 2014 | 07:38 PM
SLV's Avatar
SLV
I ended up routing my clutch cable down the right down-tube then back across. Worked perfectly. Just make sure to check for binding if you go this route.
Old Apr 11, 2014 | 08:05 PM
iDodgimus's Avatar
iDodgimus
thanks guys, i think both the clutch and throttle/idle cables will have to run by the headlamp for now...
there's a 46" braided brake line in the mail already (along with a jay brake caliper)
Old Apr 12, 2014 | 12:48 AM
hobojav's Avatar
hobojav
Default MX T-bars
Looks like you could have gone 12" or 14" MX T-bars!
Old Apr 12, 2014 | 12:56 AM
iDodgimus's Avatar
iDodgimus
The cables would have happily fit on higher bars but my arms wouldn't have :P
HD-1
Apr 25, 2017 07:52 PM
apetterez
Jan 21, 2015 06:50 AM
super2d
May 8, 2008 05:19 PM
2002fxdp
May 21, 2007 01:07 PM
lee3fan
Mar 14, 2005 03:54 PM
