How do you use the SERT?
Old Mar 28, 2007 | 01:46 AM
bobby5's Avatar
bobby5
Default How do you use the SERT?
How do you guys tune your bike with the SERT? Do you have to have a labtop? I was gonna ditch the fuelpak and buy this but im afraid its hard as hell to use. If my bike just has Vance and hines pipe and AC, does it have a special tune for just that or do you have to make a custom tune? From the way people talk im afraid to even attempt it with all the talk about maps and such. Is a dyno neccesary for it? I just want a good running bike with no decel bike and the bike run cooler and not have all kinds of crap bunched together like with the fuelpak. Does the dealer do the SERT? How much would it be if the dealer did as oppose to i did it myself?
Old Mar 28, 2007 | 02:22 AM
gman's Avatar
gman
Default RE: How do you use the SERT?
the sert is just a program on a CD that you load on a computer (probably a laptop) that has canned maps (settings for the EFI, timing, etc) that are for various combinations of HD add-ons such as SE slip-ons, SE AC, big bore kits, etc. the SERT also comes with an interface device that connects with cables between the bikes ECU and the computer. the interface device "marries) itself to the bikes VIN #, so you can't use it on another bike.
since the settings on the canned maps are for HD parts, if you install something other than HD, such asV&H Ovals or AN Big Sucker, these flow a bit different than the HD parts. you can select a canned map that is similar to what you have installed (SE AC vs AN BS). This will get you somewhat close,but not perfect. I did it on my UC, and it was still a bit lean. you can then use the sert program tomodify acanned map and then load it to the ECU.this takes some tinkering around and you may or may not get it right. having an exhaust sniffer or other tools to tell you if you are too rich or lean will help. or, you can be like me who didn't have the time to play with it and take the interface device to the dealer or someone else with a dyno and have them build you a custom map. if you do this, besides getting a copy of the dyno results (HP& torque) make sure you get a copy of the custom map from them on a memory stick or CD so that you have a copy of what they built in case you want to adjust it later, or need to reload it if the ECU were tofail. you can't retreive themap from the ECUonce it is loaded.
[IMG]local://upfiles/12616/6D19865CDA6044949B945926B5A60181.jpg[/IMG]
[IMG]local://upfiles/12616/1E2FA82065AC4896B95FABE005994374.jpg[/IMG]
Old Mar 28, 2007 | 09:20 AM
irlm1's Avatar
irlm1
hi
i have the sert on my Bob. its easy enough to use. theres a manual in the diysection - fuel injection.
i went through this before i bought and figured id be able to use it enough for what i needed, and hopefully some more.
I got mine so i could update after V7H slip-ons and hi-flow air filter, took a canned map loaded it, ran fine, some popping, some tweaking, and then some more tweaking, and no more popping and running fine.
For some extra fun, i did a data run ( a drive with the laptop on my back and connected to the ecm) and then did some tweaking in a few parts for extra power.
could do with a few more runs, maybe during the summer.
the good thing is you have full control over whats going to your ecm.
Old Mar 28, 2007 | 01:12 PM
cadman311's Avatar
cadman311
Thanks I was think about that myself.
Old Mar 29, 2007 | 12:27 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
ORIGINAL: irlm1
hi
what he said but I had mine done on a dyno and it really runs.......I had them tune it to run best when it's hot......so it runs a little rough when cold. But after 15 minutes zamma......it screams. Definitely worth the $$.......plus if you change exhaust later just retune.....as many times as you wish and save the map each time......so if you screw it up...just reload the last map...
Baranca
Apr 9, 2008 07:51 AM
LdyMjo
Mar 31, 2008 03:33 PM
swicegk
Mar 19, 2008 10:28 PM
hcherpak
Nov 10, 2007 11:09 AM
dmhosting
Jun 18, 2007 05:23 PM
