VIED Settings Dyna
Old May 2, 2014 | 07:51 AM
d_gr8_acidrain's Avatar
d_gr8_acidrain
6th Gear
Default VIED Settings Dyna
I think I was over thinking and becoming too paranoid on what to set my Vieds at so I contacted Nightrider.com and these are the responses I got. Maybe this will help others out as well;
[I]You can alter the front/rear balance if you want, but the HD EFI actually understands there is an inherent in-balance between the cylinders and has compensated for it (in the VE tables). While I never altered my front / rear cylinder balance, there is nothing to prevent you from experimenting. You really cannot hurt anything.
There is nothing wrong with the Stage 1 download, but no overwhelming reason to get it because it does not richen the fuel mixture (the AFR tables are not changed because that would put the Dealership and H-D in violation of Federal and state emissions regulations). It makes some changes to the VE tables, ignition advance and raises the RPM limit. The major disagreement we have with this download is the cost. Most Dealers charge $149 + $75 shop time for a total of $225 (average across the US). This is way too high for something we consider the Dealers/HD should provide for $100 or less (the download cost the Dealer $75, HD should give it to them for $25 or less).
Considering that exhaust/ac upgrades do not specifically need the S1 download for the engine to run, it is hard for us to recommend it unless the Dealer is going to provide it to a Rider for $125 (out the door) or less.
FYI: I do not have it in the 08 Dyna.
Most Riders like the 75% setting for the VIED on their bike like a 09 Dyna. 75% is a 13.8 AFR setting, 50% is a 14.0 AFR.
I happen to like a 14.0 setting on my own 08 Dyna.
Old Jul 29, 2014 | 05:55 AM
Dethroned666's Avatar
Dethroned666
3rd Gear
Great info, exactly what I was looking for!! Thanks!
Old Jul 29, 2014 | 12:27 PM
Foxster's Avatar
Foxster
Its this claimed AFR by NightRider that I don't get. The maximum bias you can apply to the NB O2 sensors before they are way outside their working range is about 780mV. That means the closed loop AFR will be about 14.1:1.
To get down to an AFR of 13.8:1 means biasing the sensors to 820mV or more. That's not only going to give pretty inaccurate readings, it will also reduce the life of the sensors and it might also have the bike throwing codes.
I think your idea of 50% on the Vied is a good one.
Old Jul 29, 2014 | 12:39 PM
Dethroned666
3rd Gear
Hi Foxter,
I was wondering the exact same thing, having browsed through the various EV/voltages diagrams that I've found online. However, I'm a complete noob when it comes to electricity stuff, so maybe someone else has the answer?
rs03371
Mar 26, 2013 09:40 PM
dan conner
Aug 22, 2010 03:09 PM
joflewbyu2
Jul 24, 2010 07:19 AM
28gauge
Aug 8, 2009 06:57 PM
King_O_Road
Exhaust System Topics
Sep 21, 2008 11:43 PM
