HD Quarter Fairing/Headlight Space Question
Old May 3, 2014 | 07:43 PM
Clown Shoes's Avatar
Clown Shoes
Default HD Quarter Fairing/Headlight Space Question
Question regarding the spacing on my quarter fairing and the headlight. I ride a 2011 FXDF and replaced the stock headlight with a FXDX light (complete housing unit) I recently installed a HD quarter fairing using the bung king brackets and detachable clamps. I followed the instructions - flipped the headlight mount 180 to push it forward and everything - but when I clamp on the fairing and adjust it so the headlight is flush with the rubber gasket the fairing ends up too close to the mounts, contacting the clamps and vibrating like a you know what. If I adjust it to put some distance between the fairing and the forks I end up with a good inch of space between the headlight and the gasket. The setup still allows for proper illumination through the lens but I'd like to get it right. Where did I go wrong? Thanks guys.
CS
Old May 6, 2014 | 07:45 PM
Clown Shoes
One bump.
Anybody?
Old May 6, 2014 | 08:12 PM
Odelay's Avatar
Odelay
CS
What clamps are you using? Also, when I think FXDX light, I think top mount- you mean FXD, correct? Do you have pics?
There may be multiple solutions here
Old Jun 15, 2014 | 07:26 PM
WRKD4ITFLHX2008's Avatar
WRKD4ITFLHX2008
Default same issue
yeah just installed mine have a finger gap at the bottom any fix to set flush
DynaJ
Jul 27, 2017 11:33 AM
F86
Jul 4, 2016 09:20 PM
iDodgimus
May 27, 2014 12:49 AM
JROCKER
Jan 6, 2013 11:13 AM
jasoninaustin
Oct 13, 2008 09:24 AM
