Well... Guess its time for engine work
If you have any doubts, remove them, check the threads (both male & female) and use blue thread locker (medium) and re-install them to proper torque for your model. (for most models this is 40-60 inch lbs.)
It is very sad what happened to Dynam1tes engine, and we are happy he was not hurt.
He emailed us this morning and I called him and we spoke. It has not been determined yet why this happened, but it is not a design flaw in the A/C.
This is a common design and it is still the one used by S&S and most performance manufacturers.
We are going to work with Dynam1te to find out what happened, and help him anyway we can.
DKCustomProducts.com
As far as my plans go, I'm still waiting to hear back on what's found in the cases. One thing I know is even with a scope they couldn't see the other half of the piston. But the flywheel seems to be in good shape...
Chances are I'm going to be send the bottom end to dark horse for added reliability. I'm also looking into a revolution 107 kit for the jugs and pistons. Luckily I know someone with stock heads he isn't using that I'll be getting, and I'm going to be calling Dave Mackie in the next day or two and see what he can do with em for what I'm planning...
And that'll about do it!!
Any one out there have a similar build?
While in theory you may feel that there is no need to use lock-wire, it can not hurt to go this extra step either...there is a reason lock-wire is pretty much standard in aviation components, and that reason is that a catastrophic engine failure like this is much more serious...there ain't no putting it in neutral and coasting to the side of the road and calling a wrecker...
For whatever the reason, whatever or whomever is at fault, this could have initiated a deadly chain of events. I am running a carb and there is no hardware that can go down my intake unless it comes apart...but if it were FI and I were running one of these things on my ride, it would be coming off muy pronto until the problem was resolved.
...or I would take the extra step and safety-wire the bolts and enjoy the peace of mind it affords...just say'n
My AN Big Sucker has a cover bolt. Behind that, there are 3 small bolts that thread into these long threaded 'tubes' with I believe hex heads on the tubes. The tubes then in turn thread into the backing plate. I'm assuming S&S, SE, etc use a different design.
Earlier this year someone else had a very similar issue and wrote about it here on the forum. I searched and couldn't find that thread. It was about the same thing, an air filter bolt being sucked into the motor.
