Bassani question
Old May 26, 2014 | 07:40 PM
steve5109's Avatar
steve5109
Default Bassani question
I just recently switched from rinehart crossbacks to bassani road rage 2 into 1. After installation I now have this weird vibration sound I can't track down. It's only at certain rpms. The only thing else I could think of is I ran the se flat gaskets. I was thinking about trying the tapered gasket but after googling I found some people use flat and others use tapered. It's not a heat shield sound either. Any advice? Thanks.
Old May 26, 2014 | 09:10 PM
HD Pilot's Avatar
HD Pilot
All I can say is Kurt at Bassani told me to run the SE flat too but my dyno tuner whom I have a lot of respect for told me the tapered seals better. Might give the tapered a go and see if the sound goes away. Keep checking those heat shield though because I had a little noise from them that I had to chase down.
Old May 26, 2014 | 10:29 PM
dirtdobber's Avatar
dirtdobber
If they are the new style you can use either. The new shape let's em all work. I just installed a set and used the tapered style
Old May 27, 2014 | 07:25 PM
YROC's Avatar
YROC
I have the road rage 2-1 on my FLHX and I noticed the other day while cruising at 2700-2950 RPM I had a weird vibration noise. It ended up being my screamin eagle ventilator A/C. I guess I did not torque down the bolts enough- I applied loctite this time too.
It's an awesome exhaust, congrats!
Old May 28, 2014 | 08:16 PM
steve5109's Avatar
steve5109
Thanks for the tips. I think I'll pull the exhaust back off and start from square one, with new gaskets.
Old May 31, 2014 | 07:13 PM
everythingZen's Avatar
everythingZen
5109, about 2 years ago I put on a set of Bassani RR and had this vibration sound coming from the end cone of the exhaust. what I did was to put a 1/4 inch cable clip on the vertical back pressure rod in the exhaust. It changed the exhaust flow and fixed the problem
Mborras1
Apr 24, 2019 09:25 PM
Spider0408
Aug 29, 2018 04:39 PM
LTDDD
Exhaust System Topics
Dec 1, 2007 05:41 AM
joejoesport
Sep 6, 2007 06:23 PM
chunks
Jul 3, 2005 08:18 PM
