Handling...and Apes
Old May 28, 2014 | 01:41 PM
  #41
ajmilberg's Avatar
ajmilberg
6ft tall and I run 16" Wild 1 chubbies with 1" risers, love the set up, and in the twisties I immediately noticed it handled way better than my previous 12" bars. Another possibility is always T bars, I almost wish I hadn't done internal wiring so I could swap between the apes and T bars, but I love my apes. As for hands going numb, been too busy to go on any super long rides since I put em' on, but no issues so far.
Old May 28, 2014 | 01:45 PM
  #42
fxdlx's Avatar
fxdlx
Originally Posted by nathanw
FWIW, handlebars have no effect on handling, that is determined by chassis/suspension/tire type and size, etc... what the do have an effect on is control.
What makes you think that? That is a total fallacy.
Handle bars affect where your body weight is in the fore/aft plane. You can get more weight forward on the front tire with low bars than you can with high bars. Lower center of gravity also maneuvers at speed above 70 or so better. Less sail effect.
Nothing wrong with apes or high bars. Don't kid yourself tho'
. They're not as good when you ride hard. Just like a Harley isn't as good as a sport bike at riding hard.
Old May 28, 2014 | 02:01 PM
  #43
gadianton3's Avatar
gadianton3
I have been fighting death wobbble since I bought my '12 SB new. I did everything I heard helped. Rear shocks, heavy fork oil, sputhe front & rear. All of this did help, along with trueing the wheels & proper tire pressure. But I still had it in fast sweeping turns. We are talking 35 over suggested corner speeds.
I just installed t-bars & that fixed it. I can take corners faster now & feel confident in them.
I did have the stock SB apes on there, so I don't know what it is like to ride premium brand apes. The stock ones are so light! I feel like in a corner*they were flexing & upsetting the chassis. I'm no chassis expert but that's what worked on my bike, for me.
Old May 28, 2014 | 02:02 PM
  #44
fxdlx's Avatar
fxdlx
Originally Posted by kreeess
For the non-believers.. Turning with apes !!
Seriously? That guy is probably going all of 30MPH. He's not even close to scrapping, and with stock shocks.
Old May 28, 2014 | 02:08 PM
  #45
kreeess's Avatar
kreeess
Probably... But just thought it looked cool lol... I know ive made u turns lower and faster than this but there's never anyone behind me to keep up to take a pic.. Lmao
Old May 28, 2014 | 03:15 PM
  #46
sarpeezy's Avatar
sarpeezy
The bike you see in my sig is my first bike so i basically learned on apes, rode my buddies softail the other day and it felt...boring?
And like somebody else mentioned earlier, I think apes feel way better as far as handling goes.
I say go for it!
Old May 28, 2014 | 04:34 PM
  #47
Robbie13's Avatar
Robbie13
LOSER
I have been reading this post for a while. I put on my 14". I consider it to be the same as a bigger lever when lifting or moving stuff. It doesn't take as much leverage as the smaller bars simply from the fact I have more leverage. I am more in the wind now, but that's the only downside. Choose your weapon.
Old May 28, 2014 | 05:10 PM
  #48
Warp Factor's Avatar
Warp Factor
A longer lever for turning would be wider bars, not higher.
It appears at this point that we have hardly any sport bikes with apes, and also hardly any touring bikes with apes (since the comfort of apes was claimed).
Old May 28, 2014 | 07:37 PM
  #49
nathanw's Avatar
nathanw
Weight transfer and body position is about controlling the bike, not handling and there is a difference. Everything you are talking about is control. Whatever the rider touches or does while riding the bike is about control, so you can put wider/narrower/taller/shorter bars on a bike changing the leverage you have thus altering the effort required to produce results, but the results are the same no matter what the bar is, only how much work you have to do has changed. You don't have to believe me, read Keith Code, he has forgotten more than you or I will ever know about motorcycles. That being said, you're not getting much weight transfer over the front wheel on a harley or any other cruiser type of bike based on the seating position of these bikes ( low and set back ) unless you're sitting on the gas tank.
Old May 28, 2014 | 08:41 PM
  #50
fxdlx's Avatar
fxdlx
[QUOTE=nathanw;12786969]Weight transfer and body position is about controlling the bike, not handling.That said, you're not getting much weight transfer over the front wheel on a harley QUOTE]
In that respect I have to agree. So I'll rephrase, with high bars you have substantially less control than with low bars when you are pushing a bike thats capable thru high speed sweepers.
And on the weight transfer speak for yourself. When I shift my upper body forward it puts enuf weight forward that my tire stops pushing out in corners. I know, I used to run apes.
But not everybody needs the extra control you get with low bars.
Like when they ride with lowered suspension. Apes are fine.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
