Question for the carb gurus
If so, then they have their own emulsion tube and main jet to match their needles. If you went back to a stock needle then its a mismatch.
The stock emulsion tube (AKA needle jet holder - the bit the main jet screws into) has a lot of holes all the way up. The dynojet one has just one ring of holes at the base.
If that's the case then try a stock emulsion tube and main jet (say a 180). I'd not recommend going bigger than a 47 on the pilot.
Put it all back together and fired it up...did a couple of minor tweaks on the mixture (now it is at 2 turns) and adjusted idle and now it purrs like a kitten...did a spin around the block and a short run down the freeway and this thing has never ran better since I got it. Nice burble with no blowback or decel popping and strong pull.
It seems that at some time in the past, a previous owner went Stage 1 with some 2-into-1 pipes and intake mods and put some kind of aftermarket carb tuning kit in it and never got it tuned right...taking all that **** out of the carb except the 48 pilot jet and retuning it with Harley parts was all it needed...
I am going for a long ride tomorrow and then pull the plugs and see how it is running.
I had to limp home today cause the bike wouldn't idle..
Pulled the plugs and they were pretty white... Hope I didn't burn a valve...
After pulling the carb - I noticed the retention ring was split and dry rotted..
I'm hoping that was it..
On line now looking for a place that can get me one before the 4th...
George
The manifold boot gasket you are showing will cause a vacuum leak and that will definitely cause it to idle and run rough.
The new seal did the trick - runs better than before - I always felt my idle would creep up when the bike got hot... Now with the new seal idle it's back to slow and steady. I bought the other 2 rings that go into the manifold. I'll get to them the next rainy day. I like your idea about having a spare - I'll grab another next trip to the dealer.
Going to put a 50+ miles or so on it - then pull the plugs and hope to see good things.
George
