Ignition switch moved - Street Bob
Old Apr 4, 2007 | 03:57 PM
  #31
KC99JBS's Avatar
KC99JBS
Default RE: Easy to steal?
Explain please. This is my first Harley and I've got alot to learn.
Old Apr 4, 2007 | 04:00 PM
  #32
plank420's Avatar
plank420
I would'nt worry about it. All the old bikes have it there. It looks cool. Its just easier to pop off the counsel and hot wire it.
Old Apr 5, 2007 | 09:25 AM
  #33
walterwindbag's Avatar
walterwindbag
You can hot wire all you like but you ain't going nowhere without the alarm/immobiliser fob in your pocket.
WW
Old Apr 5, 2007 | 10:47 AM
  #34
KC99JBS's Avatar
KC99JBS
Default Exactly!!!!
Old Apr 7, 2007 | 12:42 PM
  #35
walterwindbag
Default RE: Exactly!!!!
Stop Press!! I just went for my first proper ride since the switchchange and I have no turn signals, no hornand no back lights!
I think I've found out what the problem is. I wired the red feed to the common on the switch, the red/black (ignition)to one side of the switch and the red/gray (accessories) to the other side. This means at the moment you can either switch red to red/black OR red to red/gray. I do have (half)a copy of the wiring diagram and I think I should have wired as follows:
Switch pos 1 - no feed
Switch Pos 2 - red Feed to red/black AND red/gray
Switch pos 3 - red Feed to red/gray only.
Looking at the half a diagram I have if you don't have power to the red/blackAND the red/gray under normal riding half the circuits don't work.
Does anyone know for surewhether the 'regular' ignition switch feeds power to the red/black AND the red/gray for normal riding and then only to the red/gray for accessories?
I know, I know, I should have bought the manual but these are 130 bucks over here. Robbing bastards.
All the best. WW
Old Apr 7, 2007 | 07:05 PM
  #36
DougsDyna's Avatar
DougsDyna
Great job Walt!!!!!!!!!!!!! I ordered my console switch last night. Think I am going to make use of both the new and old switches for security.
DougJ
Old Apr 7, 2007 | 08:46 PM
  #37
Psycho's Avatar
Psycho
ORIGINAL: walterwindbag
All the best. WW
Yes, you are supposed to have power to both.
The proper way to hotwire one of these, is with a pair of wire cutters and a wire nut. Cut and strip all three wires, then screw all three together with the wire nut.
Old Apr 9, 2007 | 12:54 PM
  #38
walterwindbag
All the best. WW
Problem fixed:
1/ You do indeed need to have a connection between the live (red) and the red/black AND the red/gray all together to have everything working (turn signals, rear lights etc).
2/ You only need to have the red/gray connected to live for the accessories.
All the best. W.
Old Apr 11, 2007 | 06:39 PM
  #39
aaronglaser's Avatar
aaronglaser
Default RE: Ignition switch moved - Street Bob
i just installed mine!!!!!!
Old Apr 12, 2007 | 09:14 AM
  #40
walterwindbag
Cool.
WW.
