engine knock
Old Jun 20, 2014 | 10:04 PM
sideshowbh's Avatar
sideshowbh
2nd Gear
Default engine knock
I have a '12 fxdwg with the 96 cubic inch engine. When I am riding in 6th gear the engine clatters. has anyone else had a issue like this? Is it an octane issue? I run highest octane I can get at the pump. It doesn't do it in any other gear.
Old Jun 20, 2014 | 10:08 PM
HD Bobber's Avatar
HD Bobber
What performance mods do you have?
Old Jun 20, 2014 | 10:12 PM
sideshowbh's Avatar
sideshowbh
2nd Gear
vance hines big radius straight pipes. That's all as far as the drivetrain.
Old Jun 20, 2014 | 10:17 PM
HD Bobber's Avatar
HD Bobber
I was gonna say if it's maybe pinging that you hear coming from the motor cause of a bad tune, but if that's the only thing u have then it's probably not it.
Give over the entire bike and check how tight your heat shields are, pipes to the heads(those are known to rattle loose), check gas tank front and rear bolts(my buddies were loose and he only heard it in higher gears). Just double check the basics, those are the items that are always overlooked.
Old Jun 20, 2014 | 10:24 PM
SuperFastGlide's Avatar
SuperFastGlide
your not lugging the motor are you? I never use 6th till at least 65mph and up
sideshowbh's Avatar
sideshowbh
2nd Gear
I will check all the hardware first thing in the morning. Thanks, I didn't think of that.
Old Jun 20, 2014 | 10:26 PM
sideshowbh's Avatar
sideshowbh
2nd Gear
No, super fast glide. I only use the 6th gear around 65 or 70.
Old Jun 20, 2014 | 11:43 PM
C.J's Avatar
C.J
MPH doesn't mean as much as your RPM in 6th.
FATTURKEY
General Topics/Tech Tips
Apr 16, 2017 03:48 AM
SeniorChief56
Jun 2, 2012 04:17 PM
jlasoftail
May 16, 2011 10:28 PM
socal dyna
Nov 1, 2009 08:37 PM
masterblaster
Apr 10, 2007 02:11 PM
