Setting security pin
Old Jun 26, 2014 | 01:44 PM
CouchMaster's Avatar
CouchMaster
Originally Posted by Molsondrinkr
Try this maybe.
1) Have your key fob near the bike
2) Set your kill switch to off
3) Quickly turn the ignition switch on, off, on, off, on
4) Immediately press and let go of the left turn signal switch twice (press, let go, press, let go)
5) Press and let go the right signal once
6) Current PIN number will be displayed on odometer
7) Change the PIN by pressing the left signal until the desired number is reached
8) Press the right signal to cycle to the next number and repeat step 7
9) Turn ignition off when 5 digit PIN is satisfactory
NOTE: Steps 3 through 5 must be completed in quick succession of each other.
good luck
07 Softtail = My owners manual says nothing about step 2 but everything else is the same.
It would appear that newer models now use the kill switch instead of the ignition switch.
Hero
Sep 13, 2023 02:15 PM
jimjim
Mar 30, 2017 03:40 PM
Itay Frishman
Nov 9, 2014 06:54 AM
dustin1014
Jan 4, 2014 03:09 AM
fullarmor
General Topics/Tech Tips
Jul 10, 2011 06:51 AM
