Smart Security System - Setting PIN
Old Nov 8, 2014 | 05:17 AM
Itay Frishman's Avatar
Itay Frishman
2nd Gear
Default Smart Security System - Setting PIN
I own a 2014 XL1200C. I have the odometer with a digital HD combo (miles/KM). After being stuck with a working FOB one time and had my wife reduce me, I have now tried to set PIN unsuccessfully. I cannot get to the PIN setting modes.
I have tried the followings:
1) press off/run to run, tap left turn signal switch until pin present. Didn't do anything
2) turn With an assigned fob present, turn IGN key IGNITION-OFF-IGNITION-OFF-IGNITION. Press left turn signal switch 3 times. Press right turn signal switch 1 time and release. Didn't do anything.
Any other thoughts?
Thanks!
Old Nov 8, 2014 | 11:40 AM
elfnyc's Avatar
elfnyc
goto 1:20 if u want get right to it --- some dealers set their own code --- some dealers dont even touch the factory code - this will have to be figured out if the factory code does not work..
Old Nov 8, 2014 | 11:45 AM
elfnyc's Avatar
elfnyc
Setting or Changing Your Security System Alarm Override PIN
Button less fobs (Smart FOB)
Set your kill switch to off
1. Select 5 digit code ( each digit being a 1 thru 9) and record it on the wallet card in the owners manual.
2. With an assigned FOB present, turn IGN key ON - OFF - ON - OFF - ON
3. Press Left turn signal switch 3 times.
4. Press Right turn signal switch one time and release.
*Turn signals will flash 3 times. Current PIN will appear in the odometer. The first digit will be flashing.
5. Enter first digit (a) of the new PIN by pressing left turn signal (a) times.
6. Press right turn signal 1 time and release.
*The new digit (a) will replace the current in the odometer window.
7. Enter second digit (b) of the new PIN by pressing left turn signal switch (b) times.
8. Press right turn signal 1 time and release.
*The new digit will replace the current in odometer window.
9. Enter the third digit (c) of the new PIN by pressing left turn signal (c) times.
10. Press the right turn switch 1 time and release.
*The new digit (c) will replace the current in the odometer window.
11. Enter forth digit (d) of the new PIN by pressing left turn signal switch (d) times.
12. Press the right turn switch 1 time and release.
13. Enter the fifth digit (e) of the new PIN by pressing left turn signal (e) times.
*The new digit (e) will replace the current in the odometer window.
14. Press the right turn switch 1 time and release.
15. Before the module rearms, turn ignition key to OFF.
* The odometer will return to mileage display.
**Turning the ignition to OFF stores the new pin in the module.
Push Button fobs
4. Press button on fob twice
5. Enter first digit of the new PIN by pressing left turn signal until the desired number appears.
Press button on fob twice to enter number.
6. Enter second digit of the new PIN by pressing left turn signal until the desired number appears.
7. Enter third digit of the new PIN by pressing left turn signal until the desired number appears.
8. Enter forth digit of the new PIN by pressing left turn signal until the desired number appears.
9. Enter fifth digit of the new PIN by pressing left turn signal until the desired number appears.
Turning the ignition to OFF stores the new security PIN.
Using the Security Alarm PIN Override to Start Your Harley Davidson
1. Turn the IGN key to IGNITION and immediately hold both turn signal switches until 5 dashes appear in the odometer window.
2. Enter the first digit of your PIN (a) by pressing the left turn signal switch (a) times.
3. Press the right turn signal switch 1 time to move to the next digit.
4. Enter the second digit of your PIN (b) by pressing the left turn signal switch (b) times.
5. Press the right turn signal switch 1 time to move to the next digit.
6. Enter the third digit of your PIN (c) by pressing the left turn signal switch (c) times.
7. Press the right turn signal switch 1 time to move to the next digit.
8. Enter the forth digit of your PIN (d) by pressing the left turn signal switch (d) times.
9. Press the right turn signal switch 1 time to move to the next digit.
10. Enter the fifth digit of your PIN (e) by pressing the left turn signal switch (e) times.
11. Press the right turn signal switch 1 time to move to the next digit.
12. Press the right turn signal switch one time and the security system alarm is turned off.
Old Nov 9, 2014 | 06:54 AM
Kenny94945's Avatar
Kenny94945
Nice write up Elf...thanks.
Scudda
Feb 9, 2020 10:53 PM
jimjim
Mar 30, 2017 03:40 PM
glook1
Dec 9, 2014 04:47 PM
kodak86
Aug 8, 2013 07:29 AM
rickoshea45
Sep 11, 2012 10:41 AM
