Engine running lean?
Old Jul 4, 2014 | 07:32 AM
hog120's Avatar
hog120
Default Engine running lean?
Is there an easy way to tell if your engine is running lean on a new Harley without hooking it up to a machine?
Old Jul 4, 2014 | 07:33 AM
Iceman24's Avatar
Iceman24
New bike = it's lean...that's a factory tune.
Old Jul 4, 2014 | 07:38 AM
hog120's Avatar
hog120
Thanks, I realize it is air cooled, but it seems to be running hot like 270F and I don't know if that's a bad thing for breaking it in. I'm keeping the rpm are under 3500.
Old Jul 4, 2014 | 07:44 AM
Iceman24's Avatar
Iceman24
No need to baby the motor...best to set those rings tight. See MotoTune's new engine break-in routine: http://mototuneusa.com/break_in_secrets.htm
Old Jul 4, 2014 | 08:04 AM
maddghost's Avatar
maddghost
If you need to get more than a guess pull a plug and if it is all white then it's too hot. My bike runs at least 270 all the time. in traffic it goes way past 300 even up to 330. Jamie at fuelmoto set my parade mode ( sort of a cooling tactic for heavy traffic and temperature periods) to start at 400 F*. You don't need to worry. ride it like you stole it. keeping the revs down won't really help. You have to keep them up = the more speed the more wind the more cooling ability.
Old Jul 8, 2014 | 12:06 AM
hog120's Avatar
hog120
I always thought breaking in a new engine requires running it rich, not lean.
Old Jul 8, 2014 | 12:48 AM
Red Dragons's Avatar
Red Dragons
Can you elaborate more on this "parade mode"?
Old Jul 8, 2014 | 12:54 AM
Red Dragons
Look, don't be concerned with your mixture in regards to break-in. You're gonna be running factory lean until you decide to get a tuner or xieds to richen your mix. Usually you don't change your tune til you modify your intake and exhaust. But as far as break-in goes, don't baby it too much. Get the engine warm and then get on the throttle. The rings set better under hard throttle, but don't go crazy...do some hard throttle accelerations, then cruise for a bit...always keep speed changing for the first 500. But as far as temp goes...during the first 500 don't sit in traffic and let it get too hot. After 500 and when you switch to synthetic, then don't worry too much about the temps.
MDSledhead
2014-2024 Touring Models
35
Aug 20, 2017 06:57 AM
fatrob74
Sep 10, 2014 09:53 AM
DMas
Jun 1, 2009 01:28 PM
HDDyna2006
Exhaust System Topics
May 26, 2008 11:40 PM
bobby5
Apr 9, 2007 06:15 PM
