Overheating question
Old Jul 13, 2014 | 08:26 AM
Nikolaiownz's Avatar
Nikolaiownz
Originally Posted by JMC22
The amount of time stuck in traffic and the outside temp will do that, especially with a stock tune as HD likes to run the engines lien to get them thru emissions - if you get a good tuner, you can richen up the mixture - more fuel means more HP, less fuel milage and a cooler engine.
I always thought that more fuel ment cooler engine.. fuel tend to cooldown the cylinders.
and lean ment more power..
atleast that what i always thought.. dont ask me where i got it from hehe..
Old Jul 13, 2014 | 08:40 AM
Warp Factor's Avatar
Warp Factor
A leaner mixture can produce more power under some situations. But it also makes the engine more prone to detonation, so often timing needs to be retarded to reduce detonation, which can cost power. It's a fine balancing act if one is looking for maximum power.
On supercharged engines, we often run engines pig-rich under boost to keep the detonation down. They'd make more power with a leaner mixture, but then they start destroying parts due to detonation.
Old Jul 15, 2014 | 11:55 AM
jgcable's Avatar
jgcable
Thanks for all the responses but what I want to know is this...
Does the engine light flashing on my 2006 indicate that it is starting to overheat? It was a steady flash when the bike was incredibly hot and it stopped flashing as soon as the traffic let up and I was able to start riding again.
Old Aug 24, 2015 | 12:29 PM
HighGlide's Avatar
HighGlide
I know this is a year later...does your bike have a Thundermax ECM on it by chance? That is the indication of hitting 350 deg head temp on a Thundermax. It will stop flashing when the temp drops below it (after you get moving and air cools it down a bit). I've had it happen a few times.
Old Aug 24, 2015 | 04:04 PM
Reindeer's Avatar
Reindeer
I was thinking the same thing. My Tmax equipped bike has done that, not sure if the factory ECM does.
chopper345
Mar 3, 2011 11:45 AM
scoobysteve
Dec 8, 2009 02:50 PM
festus
Jul 13, 2009 08:59 PM
kevdog
Apr 8, 2008 06:29 PM
bennett
Jul 27, 2007 10:17 AM
