I would suggest you take your link apart from the shift pedal assy. If you can activate the tranny properly using the linkage then the problem has to be the pedal assy. Take it apartfrom the hub that holds it all together, clean it out and lube it and slap it all back together. Could be just dirt and grime got in there.
I have forward control, same thing happened to me last year. Shifter doesn't return, had to lift and push manually. Found the shifter shaft binding, clean it up and lube no problem since then.
When you say shifter shaft, do you mean the part that actually use with you feet?
Yes the part you change gears with cogs onto a shaft that goes into the footrest support take that apart and check for dirt or grime clean & lube like the man said!
