wrench sizes
Old Jul 18, 2014 | 11:49 AM
cerelious's Avatar
cerelious
Default wrench sizes
So I need to get some wrenches here soon, but I don't know what sizes the relative nuts are. Can any one tell me what size the rear axle nut, neck bearing nut, and fork cap sizes are? I looked in the manual for sizes but didn't see anything. Thanks all
Old Jul 19, 2014 | 11:28 AM
! rock103 !'s Avatar
! rock103 !
I know the neck bearing is 1 1/2", I'd have to check on the others which would entail removing the covers...
Old Jul 19, 2014 | 01:04 PM
TonyGinFla's Avatar
TonyGinFla
On at least 2008 and 2009 Dynas I believe the rear axle nut is 36mm and the fork cap nut is 35mm.
Old Jul 19, 2014 | 01:40 PM
cerelious's Avatar
cerelious
sweet, 35 36mm and an inch and a half. thanks for the info!
Old Jul 19, 2014 | 04:24 PM
! rock103 !
Rear axle (drive side) and fork nut both appear to be 36mm. May want a socket to torque those...
Old Jul 19, 2014 | 04:28 PM
robbyville's Avatar
robbyville
Tagging in on this since I also need to get a new set. Not to hijack but if getting a Torque wrench any suggestions on size and lbs? Would be nice to only have to buy one.
Old Jul 19, 2014 | 05:04 PM
cerelious's Avatar
cerelious
I have a 1/2in drive torque wrench up to 200 ft lbs, but I would recommend a 3/8 drive so you don't have to use an adapter to go from 3/8 to 1/2. I have a friend who is a total gear head and he told be using an adapter while torque is not a good idea
Old Jul 19, 2014 | 07:41 PM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
36 mm on the rear axle fits the best.
Old Jul 19, 2014 | 09:02 PM
dudshep31's Avatar
dudshep31
This is correct. The adaptor will "absorb" some of the torque, lowering the amount of torque actually applied to the nut.
Old Jul 19, 2014 | 09:19 PM
! rock103 !
I have a 3/8" (foot pound) torque wrench and a 1/4" (inch pound) torque wrench.
