14' street bob primary case removal
Old Jul 19, 2014 | 11:41 AM
Wes17's Avatar
Wes17
Default 14' street bob primary case removal
swapping the forward controls out for some mids and i am having to remove the primary assembly to install the shorter shift linkage that goes through the case. i've read all the how to's and i even have a manual i just want to make sure im not about to mess anything up. I've got the clutch hub nut broke loose but im having a awful time getting the clutch compensator nut off and i just want to make sure i'm not doing anything wrong.
any tips on getting the 1-3/4 nut off? (the one on the left) i dont have to mess with the star nut in the middle correct?
thanks in advance guys!
Old Jul 19, 2014 | 11:56 AM
perki48's Avatar
perki48
Looking in my manual and it says "left handed threads" so judging by your picture you may be turning it the wrong way.
Old Jul 19, 2014 | 12:21 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Just so we are on the same page,
There is nothing called the clutch compensator.
There is a clutch.
There is a compensator.
The clutch hub retaining nut is L/H threads.
The compensator bolt is standard R/H thread.
Old Jul 19, 2014 | 12:25 PM
perki48's Avatar
perki48
There is a clutch.
You are CORRECT, I flubbed up..............sorry OP.................Thanks Dan
Old Jul 19, 2014 | 12:30 PM
G-Lock's Avatar
G-Lock
I'm going to do the same project soon. Following
Old Jul 19, 2014 | 01:11 PM
DJY's Avatar
DJY
You remove the torx bolt, RH thread and its tight PS. You'll want to replace the bolt with a new one.
Old Jul 19, 2014 | 01:38 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Don`t ask me why I will never forget this...
Old Jul 19, 2014 | 03:28 PM
Wes17's Avatar
Wes17
just found this right up after searching all weekend, looks like i'll be heading to the store and picking up a t70 torx bit. thanks for the help guys!
https://www.hdforums.com/forum/dyna-...e-primary.html
Old Jul 19, 2014 | 04:21 PM
camden's Avatar
camden
Glad my thread is still useful to folks. I actually did it all twice since a fellow forum member offered to swap inner/outer primary covers a little while after I finished the initial installation.
I just used a T70 bit on an 18" breaker bar. The compensator bolt came right off. And as Dan89FLSTC said, the clutch hub retaining nut has left-hand threads, while the compensator bolt has standard right-hand threads.
Old Jul 19, 2014 | 05:56 PM
johnnyjellybean's Avatar
johnnyjellybean
No need. Just lots of red loctite. Or even the green stuff. I've reused the same one one several occasions
