Swapping trees- Steering Head Bearing/Hardware Question
Old Jul 21, 2014 | 05:45 PM
Odelay's Avatar
Odelay
Default Swapping trees- Steering Head Bearing/Hardware Question
Sorry if this has been covered, but I can't seem to find it. Here's my dumb question-
I'm planning on swapping my FXDB triple trees for some FXD trees next week. I bought a set and have had them powdercoated.
I'm doing the work myself, with a little help. I ordered a service manual to help as well. I do understand that I will need to test the bearings after install and adjust in accordance to the testing procedure in the manual, etc... But for whatever reason I cannot figure out if I will be able to use my bearings and other hardware that are currently sit on the stem in the neck of the bike when I swap to the new tree.
The triple tree came with the stem already machine pressed into the bottom clamp. Is the bottom bearing also machine pressed onto the stem- or can that and other washers, etc be taken off of the existing setup, cleaned, lubed, interchanged and swapped to the new triple tree hardware?
Thanks in advance
Old Jul 21, 2014 | 08:31 PM
Odelay's Avatar
Odelay
Sorry, would post in tech section but looks like a ghost town.
Old Jul 21, 2014 | 09:52 PM
SuperFastGlide's Avatar
SuperFastGlide
they can be swapped out... just clean and re-pack the bearings
Old Jul 21, 2014 | 10:26 PM
Odelay's Avatar
Odelay
Thanks very much
cvaria
Apr 29, 2016 08:11 AM
BluBob
Aug 27, 2012 08:48 PM
Andy-Deuce
Jun 25, 2012 03:24 PM
2NAHNTR
Feb 21, 2009 04:07 PM
incrediblah
May 7, 2008 06:19 AM
