drained oil. dip stick reads full
Old Aug 1, 2014 | 11:51 PM
gusotto's Avatar
gusotto
Originally Posted by apetterez
which plugs are whichand if I did drain the tranny how do I replace the oil I drained
You have three drain plugs and three openings for the engine oil, primary and tranny.
All taking different oils.
I'd find a buddy (or manual) before going too far as you can screw up the bike with not getting the fluids in the correct spot.
Don't mean to sound cruel but it sounds like you are lost while changing oil.
Other riders are always willing to help.
Old Aug 2, 2014 | 01:35 AM
03Custom883's Avatar
03Custom883
I have the same bike. Here is link on how to change your oil
apetterez's Avatar
apetterez
I know the primary is where the derby cover/ clutch inspection. Cover is. On the left side.
On the right side where the cam cover and dipstick is has two drain plugs. One in front and one in back. Which is which?
Old Aug 2, 2014 | 02:17 AM
ynots's Avatar
ynots
Old Aug 2, 2014 | 02:21 AM
gusotto's Avatar
gusotto
That previous oil change video was good. Watch it.
Did you remove either plug?
I have an Ultra but I'd guess one plug is for the oil and the other for the tranny. Less oil will be in the tranny. About 3 qts. will come out of the engine. You'll know the difference.
The primary drain is on the left. Watch the other videos that load after the engine oil video. Primary oil will go in on the left side.
Good luck and watch those Youtube videos.
Old Aug 2, 2014 | 02:38 AM
apetterez's Avatar
apetterez
I drained the tranny. How do I refill/check tranny fluid? What type of fluid do I use?
Old Aug 2, 2014 | 03:48 AM
Ron750's Avatar
Ron750
Should look like this:
The Drain plug is labeled Mag Plug. Replace the O ring every time. Some dealers give you one free, some charge a dollar. There are threads on buying them in bulk for much less. I will post on that later.
There are many Tranny threads with what to use. Do a search.
Old Aug 2, 2014 | 03:54 AM
Ron750's Avatar
Ron750
Old Aug 2, 2014 | 04:59 AM
jmb79's Avatar
jmb79
Awesome photoshop Ron750, and a perfect explanation.
Old Aug 2, 2014 | 05:07 AM
Campy Roadie's Avatar
Campy Roadie
I'd just ride the bike if the dip stick showed full It'll sort itself out. After you pay for that, you'll know the difference between the oil and transmission drain plugs.
