99 Dyna Wide Glide
Old Apr 6, 2007 | 07:07 PM
Hosman's Avatar
Hosman
Stage II
Default 99 Dyna Wide Glide
I just recently had My Dyna put on a Dyno tester, because it seemed to be very slow to accelerate after about 3000 rpms, and while I had lots of throttle
left I would get no response. In other words, it was falling on it's face at higher rpms. The dyno tester said the fuel air mixture was ok, but other than that he was stumped. In his words, "it's almost as if something was dragging the engine down" he checked spark and brakes but could not come up with any clue to this symptom. I have stage one and straight pipes installed with no baffles. I just bought this used so don't know how it ran before. Any Ideas from you more experienced bikers?? I would just like to have some direction before I take it to a certified Harley shop.
Thanks
Old Apr 6, 2007 | 07:28 PM
Hosman's Avatar
Hosman
Stage II
Default RE: 99 Dyna Wide Glide
I forgot to mention It is a '99 with 45,000 miles on it. In all other ways it is a well cared for and extremely good condition bike.
Old Apr 6, 2007 | 09:44 PM
99superglide's Avatar
99superglide
I have a 99 fxd tc88 with A.N. bigsucker and jet kitand can tell from experimenting that straight -pipesreallyreduced the mid-range.After I putlouverd bafflemufflers back on it reallycomes to life between 3k-4500 rpm.
You should try to get about any brand of baffled slip ons and you should notice the same difference. You can spend anywhere from $100 to $500 for them but they will probably fix your problem. Seems like alot of people buy the Krome works for about $ 180 or so. Look in the J&P cycle wishbook.
Simple things first would be try putting some fresh gas in it. Clean the air filter, Change the plugs.
It may also have something to do with the carb even though your ratios were ok. Hope this helps you out some. Keep me posted on how it turns out.
Old Apr 6, 2007 | 10:09 PM
05 Wd Gld's Avatar
05 Wd Gld
Did you do a compression test on it?
Old Apr 7, 2007 | 12:36 PM
Gary_L's Avatar
Gary_L
A 2:1 exaust, dual pipes with a crossover chamber such as the Vance and Hines, or stock headpipes with slip ons should solve your problem.
You need some kind of crossover and some back pressure to get the most out of your motor.
Old Apr 7, 2007 | 01:05 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
ORIGINAL: Gary_L
What he said.......ditch the straight pipes for a 2 into 1
Nagoc
Jun 4, 2013 09:49 PM
HRCH
Aug 22, 2012 12:56 PM
pimpygrub
Exhaust System Topics
Feb 25, 2010 06:29 PM
28gauge
Dec 10, 2007 08:02 PM
skankaholic
Mar 1, 2007 08:47 PM
