dying at idle
Old Aug 18, 2014 | 02:26 AM
jameserss's Avatar
jameserss
Default dying at idle
I asked this in sportster thread and didnt get a reply any ideas?
2009 sporty dies at idle then when i turn the key off and try to restart the display goes blank. In the accessories/ first position the speedo lights up but in the second position the speedo goes dark. Not sure the problem, used volt meter to check the charger pigtail got 12.4v any help would be great.
Old Aug 18, 2014 | 12:33 PM
nevil's Avatar
nevil
The first thing I do when there's an idle problem is to clean the IAC with some throttle body cleaner.
I don't know if it's related to your other problem or not. The battery may check out OK sitting but it needs to be load tested. And check all the battery connections including the grounds.
Old Aug 18, 2014 | 12:41 PM
DesertDyna's Avatar
DesertDyna
+1 on checking grounds. Loose ground cable at the fender or the battery is a common cause of all kinds of electrical issues.
peci02@bellsouth.net
May 15, 2020 11:31 AM
misterslim
Oct 29, 2017 01:13 AM
Bad Pig
Mar 19, 2016 08:34 AM
Mark Howden
Dec 19, 2015 10:19 AM
jameserss
Aug 18, 2014 10:24 AM
