Red light?
Old Aug 25, 2014 | 10:23 AM
AllenW's Avatar
AllenW
Default Red light?
I have a 2012 wide glide and just to the right of where the speedometer shaft goes into the dash there is a red light that comes on when the ignition is turned on, goes out for a couple of seconds when motor is started and now comes back on.
I have the shop manual, and can't find any info on it, I put the owners manual somewhere I wouldn't loose it, and can't find it now.
Anybody know what that light is for??
TIA.
al
Found it, low beam out.
Old Aug 25, 2014 | 10:50 AM
Reindeer's Avatar
Reindeer
I think that's the security light. If its staying on that means theres a code in the turn signal/security module. Mine flashes when I use the turn signals because I have LEDs in the front with different resistance and I'm too lazy to wire in the correct resistor.
Theres a sequence of buttons to push/hold that will display the codes in the odometer, but I can't remember how to do it.
Edit:
Here it is. https://www.hdforums.com/forum/dyna-...lear-them.html
Old Aug 25, 2014 | 10:52 AM
AllenW's Avatar
AllenW
There's a sequence of buttons to push/hold that will display the codes in the odometer, but I can't remember how to do it.
Thanks, turns out low beam out.
I'll save that thread though, thanks.
Al
Old Aug 25, 2014 | 10:54 AM
Reindeer's Avatar
Reindeer
Headlights are important.
surfnorthwest
Jan 19, 2022 10:43 AM
FinalShot
2014-2024 Touring Models
Oct 3, 2017 10:29 AM
fatguy-littlebike
May 28, 2012 02:02 PM
ko4qc
Jun 16, 2009 12:28 AM
doomie19
Mar 27, 2007 01:24 PM
