Motorcycle jacks
Old Sep 1, 2014 | 05:55 PM
ynots's Avatar
ynots
I went with the Sears Craftsman (red) and did the mod. Ive been using it for over 4 years and it has worked just fine. Regardless of what you purchase be sure and use the locking bars and strap it down
Old Sep 1, 2014 | 06:43 PM
DJY's Avatar
DJY
Originally Posted by 2500hdon37s
the tires will be fine. you might get a tiny flat spot at the most, and those would go away in the first mile or two.
I'd rather my bike sit on the tires and kickstand as intended rather than on a jack where it could possibly fall over.
Put it on a J and S, it's not falling over.
Old Sep 1, 2014 | 06:51 PM
grumpy56's Avatar
grumpy56
Ditto on the J&S. No need to tie it down. However, you still need to be real careful how you position the J&S under the bike as that oil pan and all sorts of frame contraptions can get in the way. Real pain actually if you ask me, but once you get it up there, your scoot ain't going anywhere.
Old Sep 1, 2014 | 07:11 PM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
Harbor Freight has some nice ones for under a hundred bucks.
Old Sep 1, 2014 | 09:19 PM
Gommee's Avatar
Gommee
Devil's Advocate
I picked up a set of these scissor type jacks. I use them to work on the bike as well as store it for the winter. Really stable, they lift over 1000 lbs, and raise to about 16" or so.
Use one or both.
Old Sep 1, 2014 | 09:22 PM
gant's Avatar
gant
Use one or both.
got a pic of your bike using these?
Old Sep 1, 2014 | 09:43 PM
Gommee's Avatar
Gommee
Devil's Advocate
I will have to search around to see if I can find some pics, I do not have the bike right now to take pics. I swerved to miss a deer back on July 11, hit the ditch and ended up spending 5 fun filled days in two Montana hospitals. I have almost almost finished healing, but my bike is sitting at a HD dealer up here. It took them almost 2 months to get it transferred up here and I am still waiting on whether they are going to repair it or write it off.
The jacks work great, extremely stable.
Old Sep 1, 2014 | 10:01 PM
Gommee's Avatar
Gommee
Devil's Advocate
These are the best pictures I could find of my scissor jacks.
Attached Thumbnails Motorcycle jacks-2013-10-28t22-03-57_237.jpg   Motorcycle jacks-2013-10-28t22-03-55_102.jpg   Motorcycle jacks-2013-10-28t22-03-55_155.jpg
Old Sep 2, 2014 | 01:05 AM
ShiftyCapone's Avatar
ShiftyCapone
DO NOT waste your money on the Harbor Freight High Position Motorcycle Lift. I honestly do not know how there are 55 reviews and 4.5 stars. The arms flex like crazy with my ~685lb Wide Glide on it. I have to have another person with me to lift the bike and I also use a floor jack to help support the front arm and stabilize/level the bike.
Old Sep 2, 2014 | 08:25 AM
littledragon's Avatar
littledragon
I guess my question would be how does the J&S pick the bike up level without an adaptor when mine and the others mentioned can not? Is it wider or narrower than mine which is 15" wide from outside of each pad to pad and each pad is 3" wide.
