Motorcycle jacks
Old Aug 31, 2014 | 07:22 PM
littledragon's Avatar
littledragon
Default Motorcycle jacks
I have an FXDC that I would like to lift and take the weight off the tires for clean up and winter storage in my unheated shed. I currently have a jack called the OTC Stinger. It is a nice jack but I don't think it will work to lift the Dyna for a couple of reasons. First there seems to be a welded strip of steel 5 inches or longer on the right frame tube that seems to be there to protect some wiring that runs in a rubber/plastic tube along the inside of the right frame tube. This would make the bike unleveled when lifted as it makes that side of the frame about an inch lower than the left side. Second the kick stand spring hits the center brace of my lift when I try to get it far enough under the bike to attempt a lift with it.
Does anyone own a floor type lift jack that will lift a stock 2012 FXDC and is stable enough for leaving it up for the winter? If so I would appreciate your replies.
Old Aug 31, 2014 | 07:34 PM
TGGazoo's Avatar
TGGazoo
I just use a normal moto/atv jack on mine. ('12 FXDC, stock height) Sat level and all. Had to run the front tire onto a couple 2x4s to get the frame up enough to get the jack underneath.
Old Aug 31, 2014 | 07:59 PM
DJY's Avatar
DJY
J and S.
Old Aug 31, 2014 | 08:19 PM
rooti's Avatar
rooti
J and s is probally the best jack on the market and it will lift your dyna up level and solid without adapters. I have always used the J&S because my brother owned one and he lived across the street. When he moved, Lowes was clearing out their jacks for 39.99 so I couldn't resist buying it and spent another 20 bucks to modify it. Now it is as solid as a J&S but I did spend some time getting it that way.
Old Aug 31, 2014 | 08:23 PM
slyedog's Avatar
slyedog
I have same jack. Goes down way too fast. Dangerously fast. Got new cylinder still same. You can buy Dyna lift blocks that accommodate the Dyna frame for like $25. Will buy some till I can get rid of OTC and pick up something better.
Old Aug 31, 2014 | 08:30 PM
tully_mars's Avatar
tully_mars
J and S I read is very good. After seeing the Pitbull lifts in action I got one. Really a nice lift and have enjoyed mine for 2 years.
Old Aug 31, 2014 | 09:11 PM
maddghost's Avatar
maddghost
Your jack will work if it can lift over 700 lbs with a 1"x3"x3" block of wood under the tube on the primary side, opposite side to the one you described.
Old Aug 31, 2014 | 09:30 PM
IdahoHacker's Avatar
IdahoHacker
Originally Posted by slyedog
...You can buy Dyna lift blocks that accommodate the Dyna frame for like $25...
Where? I'd love to find something other than a block of wood.
Old Aug 31, 2014 | 09:31 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
1st choice should be a J&S.
2nd choice should be a Pitbull.
Old Aug 31, 2014 | 09:43 PM
fatbobsd's Avatar
fatbobsd
How big a deal is it to leave the bike on the tires all winter? I will be leaving mine in am unheated garage for the winter. Is it better to lift it off the tires?
