Speedo backlight started flickering last ride..
Old Sep 1, 2014 | 06:34 AM
Nikolaiownz's Avatar
Nikolaiownz
Default Speedo backlight started flickering last ride..
top says it..
Seems to happen only when the engine runs.. anyone had that problem? maybe a lose ground somewhere?
Cheers
Old Sep 1, 2014 | 07:02 AM
1HD1C's Avatar
1HD1C
stock gauge o speedo/tach unit??
dont know about stock unit as i didnt run mine long enough to notice BUT the speedo/tach unit has an eye that detects bright light and turns off back lighting
thought something was wrong with mine last year when I was riding in and out of shade and it kept going on and off
Old Sep 1, 2014 | 07:36 AM
Nikolaiownz
Sorry i dident mention that.. its stock speedo... does that have that eye?
Old Sep 2, 2014 | 06:18 AM
1HD1C's Avatar
1HD1C
sorry I couldn't tell you as I said I didn't run my stock gauge long enough to notice
if you have an owners manual take a look in the gauges layout section
Old Sep 3, 2014 | 08:18 AM
Nikolaiownz
I found the problem.. is was a lose ground..
Old Sep 4, 2014 | 06:12 AM
1HD1C's Avatar
1HD1C
excellent that you found it, electrical problems can be tough to trace sometimes
Old Sep 4, 2014 | 06:52 AM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
I thought the same thing about my 2012 Superglide it does that too
Old Sep 4, 2014 | 08:31 AM
Chase1961's Avatar
Chase1961
Glad you found your problem. I had to take my bike back 3 times (under warranty) to get my speedometer light fixed. Finally had to replace entire unit.
Old Sep 4, 2014 | 08:38 AM
Deadhead77's Avatar
Deadhead77
My 2012 FXDC does the same thing. Only during daylight has never done it at night. Can you explain where the loose ground was?
Old Sep 4, 2014 | 08:55 AM
Chase1961's Avatar
Chase1961
The back light should only work at night, and in dark areas like a garage or heavy shadows. It has a light sensor that turns it on.
